Question about Lexmark X1270 All-In-One InkJet Printer
Offline lexmark printer is offline checked paper checked cartridge unpluged & pluged back in still will not print
  • 62 Answers
Did you try right clicking the Printer icon in Windows and select Use Printer Online?
Posted on Oct 05, 2007
SOURCE:
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
My lexmark Z2300 will not feed the paper. The roller in the back (by the paper) does not move. I just changed the black ink. It has also said communication problem when I tried to print. NOW when you...
Disconnect the printer from your pc. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check the cartridge area and make sure there are no obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip) behind the carrier. If everything looks fine, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Close the cover. Reconnect printer to the computer. Try to print again.
May 24, 2011 | Lexmark Z2300 InkJet Printer
Lexmark x4270 all-in-one problem with Windows 7
I really appreciate your patience. Thank you for choosing Lexmark glhall53!!!
Apr 29, 2010 | Lexmark X4270 All-In-One InkJet Printer
Can't get the printer to print. tests work, but when i go to print a document, nothing. says the printer is offline. i'm on vista
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Lexmark Z611 InkJet Photo Printer
Wont print just paper feed
1. check to see if you have the cartridge installed and or that the ink cartridge isn't empty.
2. Clear all print documents in the print queue.
3. unplug the printer then wait 30 seconds . Plug back in and try to print again
Apr 19, 2010 | Lexmark X73 All-In-One InkJet Printer
My lexmark x5630 has been showing paper jam but there is nothing inside the printer thats stoping it please help.
Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Printer is "offline" and will not print
turn the printer off remove ink cartridge refix it again.then check.also check ther eis not any paper jam in printer.
Jan 05, 2009 | Lexmark X7350 All-In-One InkJet Printer
Error codes 1201 and 1203
Hello, erorr 1203 is telling you there is one of a few issues with your cartridge/s. Check the contacts are cleaned and printheads. Make sure there are no paper jams. Reset the printer by turning it off and completely unplugging it and replugging it and turn it back on again. Clear print queue, check it is set to work offline in settings. Press copy and copy something and see if it is ok now. Error 1201 is a communication issue with data where your cartridge has stoped for one or more reasons and h eprint data was not completed or used. Try the reset to fix this too. Post back if no good. Don't forget to clear print queue.
Nov 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Problems getting windows vista to see my lexmark x1185 .
  1. Temporarily unplug the power cord from the wall outlet and then plug it back in.
  2. If necessary, turn the printer back on. It should make a resetting sound.
  3. Check that the print cartridge has been snapped into place.
  4. Make sure the printer is directly connected to the USB port on the PC.
  5. If another peripheral device is connected, remove it and connect the printer directly.
Nov 24, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1270 All-In-One InkJet Printer Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
