Question about Lexmark X73 All-In-One InkJet Printer
Printer The paper feed is the problem. The paper feeds to the left and then crumples up. Any idea how to fix the feed so it takes the paper in even?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 123 Answers
You can try cleaning the rollers with water and mild soap. Also, try taking an air can to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Posted on Apr 04, 2016
    Novelist:
  • 69 Answers
I have seen your issue on the paper feed for your printer. Well, I am thumu from india-Hyderabad. I would like provide my solutions on the issue.
This issue could happen due to the following below causes:
1. If you are not using the recommended Paper type for your Printer
2. If you feeding the Paper incorrect.
3. if paper type selected in the Printer Properties and the paper type that are trying to feed are mismatched.
4. If there is an issue with Paper Feed Rollers of your Printer. Or some times, the issue could also happen if there is some dust on the paper feed rollers.
5. If there is an issue with Printer software might have got corrupted.
Try below solutions :
1. Check whether the issue happens with all applications or not.
 If it happens with all applications, then we need to troubleshoot further or if it happens with Particular application like MS-word, then we need to check the Print settings.
2. Make sure that you are using Correct and recommended Paper type for Printing and same paper type is selected in the Printer Properties.
3. If the issue still happens, then please disconnect the Printer from Wall outlet and from Computer, try to clean the Printer paper feed rollers . Please look in to Manual or Instruction set that is given with Printer to clean Paper feed rollers.
If the issue still happens, then I suggest you to opt and go for online Chat Support  for your Printer. They can help you with much more information.
For your convienience, I would like to provide you web link for Online Chat Support for Lexmark Printers.
http://support.lexmark.com/cgi-perl/support.cgi?ccs=229:1:0:520:0:0&
Once if you open the web page please click on the chat Support . This will get you to live Chat Support agent.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com if you need any further assistance on any issue. I'll be glad to help you.
Posted on Oct 17, 2007
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Faulty paper feed
There is a sticker or piece of paper inside the printer. TO fix this, some parts needs to be removed so the foreign object obstructing the paper path can be removed from the printer.
Apr 15, 2010 | Lexmark X4550 Multifunction Wireless Color...
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hp officejet 7310 allinone
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper gets crumpled and wrinkled and won't feed.
is printer new i would take it back if u can if not go lexmark.com download ther latest driver ok may fix it up best u can do try feeding paper throw it fe w times train it
Oct 09, 2008 | Lexmark X2600 InkJet Printer
Paper feed problem
Good luck...
Sep 11, 2008 | HP DeskJet 6540 InkJet Printer
Canon i9950 feed issues
Apr 26, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
Lexmark X73 All-In-One InkJet Printer Logo
229 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
