Question about Linksys EtherFast Instant GigaDrive 80 GB Hard Drive Array
Linksys EFG80 repair / drive retrieval
Have an out-of-warranty Linksys EFG80 which is not operating. Linksys states they do not repair their own equipment out of warranty. Their new NAS (NAS200) is unable to read the drives. Need to have the EFG80 repaired or if not possible a means to retrieve the data from the disk drives in use with the EFG80. Thank you.
  • 1 more comment
  • ArronA Oct 02, 2007
    Thank you for your input. Linksys Support has stated a Windows XP machine is unable to read the drive(s) directly due to the Linux OS in the EFG80.
  • Anonymous Dec 10, 2007
    lost password
  • venteck0 Apr 16, 2009
    It seems some of my drives are working. Based on the previous comments their FileSystem seems to be based on a version of Linux. Does anyone know what version of Linux may that be?
    Thank you,
    Ruben Nieves
Haven't tried this, but get UBCD http://ubcd.sourceforge.net/download.html
install the drive as a second drive in an XP machine and boot from the UBCD disk. It should read both the NTFS and the Linux drive.
Good luck.
Posted on Nov 14, 2007
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Linksys EFG80 repair
apparently the EFG80 uses a particular brand of linux for it's operating system.
if you mount the drive in a machine running linux you should be able to read a retrieve the data.
Posted on Jan 02, 2011
It's not working power comes through the power pack but it's not working now. i want to know about my warrenty period of this hard drive.
Your warranty from seagate will cover replacing the hard drive but will not cover the cost of retrieving any data that was on the drive. If you have any data on the drive you need recovered be sure to deal with that before submitting the drive for warranty.
To determine if your hard drive is still under warranty go to:
http://support.seagate.com/customer/en-US/warranty_validation.jsp?form=0
enter your serial number, model number, country and fill in the capcha box then submit, Their site will verify your warranty status. If there's no data you need on the drive and it's in warranty, simply follow their directions to get the drive repaired or replaced. If you have data on the drive you need, reply back with your location (Country, State, City) and I will recommend a data recovery facility near you.
If you're off warranty and do not have data you need on the drive you can take the drive to a local computer shop and ask the technicians to disassemble the enclosure and test the drive inside. If the drive is ok and the enclosure has failed, the technicians should be able to move the drive into a new enclosure for about half the price of buying a replacement external drive.
Hope this helps FixYa,
Chris
Jan 11, 2011 | Seagate (ST315005EXD101RK) 1.5 TB USB 2.0...
My computer a few weeks ago over heated I let it cool down and when I switched it back on again it no longer could find any wireless routers this probem was fixed by doing a system recovery bat in one day...
Not finding the operating system comes from the hard drive. You may have a drive that is failing. You should have it checked before it fails completely. While it is in this state, the data can still be retrieved by a repair technician.
Oct 31, 2010 | Computers & Internet
My externai wont turn on either
Hi there!
If the power LED is not lit and you can't hear the drives spinning up, it's likely that the reader head is stuck. That beeping you hear is a diagnostic code indicate there is a problem.
It won't be easy to recover that data unless you are prepared to pay a large price, as the only location capable of retrieving the data safely is usually a clean room.
Before you resort to that option, try to find a local repair shop and they will typically provide a free diagnosis and will let you know if they can retrieve the data in-house. If not, that's when they will ship it to a clean-room at your request.
The cost can range from $500 to $3000 depending on the type and amount of data on the drive.
I hope this helps!
Aug 27, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Acer aspire 2920z cannot boot hard disk drive
Well either way it's probably not a good thing. You've either lost critical files or damaged the boot sector of the drive. The question is do you have valuable files on that hard drive that you need? If the drive is going bad, the more you run it the less chance you have of retrieving those valuable files. If you know how you can put in the XP CD and boot off it and do some repair but DO NOT try to re-install Windows at this time as it may try to format your drive and then your valuable files will be gone. You should have some professional help to try to repair your current windows. The best way to solve this is to probably get another hard drive as they are pretty cheap. Exchange drives and re-install windows then get someone knowledgeable to retrieve your valuable files from the old hard drive then send it back to the manufacturer and see if you can get a new one on warranty and keep it for a spare or sell it.
May 31, 2009 | Acer Computers & Internet
Boss 1180 Hard Drive Error
Im Sure You Solved This Problem But For Other User Yes There Is A Way To Save Your Data If Your Hard Drive Is Still Operable. You Can Put Your Boss Hard Drive Into Your Computer And Copy Its Contents To Your Computers Hard Drive. Some Say That If The Hard Drive Is Not Operating You Can Put It In A Ziplock And Then Stick It In The Freezer For An Hour Then Attempt To Retrieve Your Info. Remember Always Back Up Your Data On Hard Drive Recorders As They Are Not Fail Safe.
Apr 13, 2009 | Boss Micro BR Digital Recorder
Laptop
A blue screen is an operating system error. this can be caused by either a corrupt operating system or a failed hard drive. What you will need to do is run a system repair with your recovery or operating system disc. If the repair doesn't take then reformat the hard drive and install a fresh operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 26, 2008 | Dell Latitude D800 Notebook
Where
There are a variety of things that can malfunction on your external hard drive:
1) The USB cable - Have you tried switching the USB cable?
2) The external hard drive casing
3)  The hard drive itself
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
I/O Magic Technical Support
May 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Oct 02, 2007 | Linksys NAS200 Network Storage Server
Open Questions:
See all Linksys EtherFast Instant GigaDrive 80 GB Hard Questions
Linksys EtherFast Instant GigaDrive 80 GB Hard Drive Array Logo
529 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
