Question about Sony PlayStation Portable (PSP) Console
PSP System won't recognize battery. Can only play as long as plugged in. Tried new battery, same result. Any ideas?
This link might help.
If you're still having problems you'll have to return or repair the unit.
Phone Number
1-800-345-SONY (7669)
Hours of Operation
Monday through Saturday, 6:00 a.m. to 8:00 p.m.
Sunday, 7:00 a.m. to 6:30 p.m., Pacific Time
Posted on Dec 20, 2007
SOURCE:
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
PSP 2001 not recognizing battery
yes,and try using the right battery for ur system
Feb 10, 2010 | Sony PlayStation Portable (PSP) Slim...
My PSP will start if it has no disc in it but if you start a game it will shut down. If you start my PSP with a disc in it, it will power up but won't load any icons. I have tried both these senarios with...
Sounds like you have two options. Call SONY and tell them you love the psp but its crapped out on you. See if they charge u a bit of a fee for some replacement or something.. good luck. THE OTHER THING you could do is find pandora battery, and go custom firmware. That would be like restoring it to its original state, or a new custom firmware state. Thatd do the trick. if you are bold enough to try.. Google the rest playful soul!!
Dec 01, 2009 | Sony PlayStation Portable (PSP) Slim...
Charger?
As far as linloo goes the connector (the yellow part on your psp) sounds like it's going bad or it is bad. You can find it on the net for repair and should cost more than $4-7.
k_cullen95
Do you have access to another psp? Okay so you say you have tried plugging it into different outlets. It could be the adapter (charger might be bad) But the only way to test this is to put your charger on another psp to see if it charges. And vise versa with the other person charger on your psp.
And just in case you may want to check the battery and or the conector. By doing the same method I just said.
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Custom firmware
Earlier you have said that you were able to play games from memory stick and since you updated your psp firmware the didn't worked.
First Check your current firmware version . To do this go to
Settings > System Settings > System Information on your PSP . If you your version showing  for example 5.00 M33 you are still in Custom firmware. In this case you should able to play the games from memory stick. or else you memory stick is back... or you custom settings are wrong.
If its showing  for example 5.00 you are with Sony's official firmware. In this case you wont be able to play the games from  memory stick. From here to make your PSP play the games from memory stick you need to Downgrade your PSP. Only way to make this possible is through Pandora Battery and Magic Memory Stick.
So please check your version and let me know so i can guide you further. Also tell me whether your PSP is PHAT or SLIM & LITE..... or check the version of your PSP by removing the battery. Underneth it find some letters and numbers PSP-100x / PSP-200x / PSP-300x
Nov 16, 2008 | Sony PlayStation Portable (PSP) Console
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
