Question about Brother HL 1440 Laser Printer
LED lights All my LED lights are flashing - we had a power outage the other day and I'm assuming this results from that. Your web site says I have a CPU runtime error and that I need service. Is this a big deal? did I fry my printer?
  • Anonymous Jan 18, 2009
    I have a 1440hl printer and after A POWER OUTAGE ALL LIGHTS ARE FLASHING AND NOTHING I CAN D O SEEMS TO HELP. iS PRINTER FRIED?
    Genius:
  • 1,601 Answers
Http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=us&lang=en&prod=hl1440_all&Cat=11
If you see any of these service call indications, turn off the power switch, wait a few seconds, and then turn it back on and try to print again.
Note
    They will tell you if it is fried
Posted on Nov 03, 2007
6ya staff
SOURCE:
LG Tv backlights won't come on. Replaced bad LED strips and did not fix. Should I move to replace power supply/LED driver?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
Jun 28, 2018 | LG Televison & Video
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
My hisense pulse stopped working. Now on power up the screen flashes hisense and then blue screen with no signal. red led flashes at first and then nothing.
Sounds like corrupted firmware. A firmware update might be necessary. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 04, 2015 | Hisense Televison & Video
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Aug 11, 2011 | Sharp LC42D65U 42 in. LCD HDTV
I HAD A POWER OUTAGE AND THEN MY POWER SUPPLY LED HAS BEEN FLASHING AND MY PC DOES NOT RECOGNIZE THE OUE UNIT. I ASSUME THIS IS A POWER SUPPLY PROBLEM.
Find an electronics technicican with a "MultiMeter" -- they can measure the voltage and amperage being emitted by the AC adapter, to see if is within specifications.
Otherwise, take the Que! to a qualified computer technician, for further diagnostics.
Jan 23, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
Green light flashing on the back of the cpu
Your power supply just died. If you don't have a surge protector, the power outage probably sent too much voltage to your computer. A power supply is relatively easy to install, but you do have to have some knowledge to do so.
Try looking at this: http://www.fonerbooks.com/r_power.htm
If you don't understand it, you should be able to get someone to replace it for you for relatively cheap. Also, you can get a new power supply for about $20 on E-bay.
Also, make sure your computer-- and all major appliances-- have a surge protector on them, because this kind of stuff happens ALL THE TIME.
Apr 04, 2009 | HP Remanufactured Compaq Presario SR1130NX...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Brother HL 1440 Laser Printer Logo
264 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
