Question about Proscan PSVR65 VHS VCR
VCR Display Panel
Display panel will not light up. Like the bulb burn out.
  • jerry dow Oct 03, 2007
    VCR not under warranty--9 years old
    The problem happened gradually and finally went blank.
    The VCR still works, but can't see the screen.
    Novelist:
    Scholar:
  • 149 Answers
It sounds like the LED might be burned out of it. Is your VCR still under warranty? If it is, the manf. can replace it at no cost. Otherwise an LED doesnt cost that much to replace if that is the problem. Did it do anything else before the problem happened? Does it still work now? But you cant see the screen is all?
Posted on Oct 02, 2007
SPEEDOMETER WILL NOT ILLUMINATE 1989 CADILLAC ELDORADO
All instrument panel lights or just speedometer light? There are several bulbs behind instrument panel. More than likely, the bulb at speedometer is burned out, and can be replaced by removing instrument panel and replacing bulb(s). Hope this helps.
Nov 12, 2013 | Cars & Trucks
Changing the light bulb on display control panel
The bulb is located behind the panel under the light cover and this unit takes four bulbs to light up the refer section. The bulb you seek is directly behind the display and computer unit mounted to the celling of the refer section.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 01, 2013 | Sub-Zero 690 Side by Side Refrigerator
I have a Sharp R1200 Microwave oven and the internal Light bulb burnt out, and the digital LCD does not display all charaters, Is this something a homeowner can repair ? FYI I am very technical so as long...
Hello William,
I see you got back to me and I dowloaded the manual, but not sure how to repair this microwave, the inside light is burned out
and the display numbers do not light up correctly, as if some of the pixels are burn out. So I need to know what I need to replace ( LCD panel)? where is the bulb located and how do you remove and replace it, It should be easy once I know what and where to go
Mar 22, 2010 | Sharp R-1200 Microwave Oven
AC display panel lights
You will need to replace the whole in-dash A/C control unit. Changing the small bulb won't rectify your problem, as the display is LCD.
Mar 12, 2009 | 2001 Chrysler 300M
Instrument cluster panel
Not a Fuse. There are Small Bulbs on the Back of the Guage Cluster that Burn out Occassionally. You will need to Disassemle the Dash and Remove the Guage Cluster to get to these Mini-Bulbs for Replacement. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 29, 2009 | 2002 Buick Century
Replacing dash lights
You may be able to reach the bulbs from the back of the instrument panel, you will need to remove any lower panels that block access, if they can't be removed from the back then you will have to R&R the instrument cluster assy and any other unit that has defective bulbs, make sure you get the correct repacement bulbs, they may look the same but have diffwerent luminosity ratings, wrong bulb will be to dim or to bright and hot burning, this can damage the bulb socket, check your owners manual for more info.
Aug 04, 2008 | 1997 Audi A4
Indicator Panel on Quasar VCR
Display tube is needed...accordianman
Feb 11, 2008 | Televison & Video
Televison & Video Logo
80 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
