Question about Canon PowerShot A550 Digital Camera
Battery power down
I've changed my batteries several times and eachtime I power up the camera it says to change the battery and shows me the flashing low battery icon. I've looked on the forums and there are several theories: one says the contact isn't working, the other says there is dust in the lens. THis camera is fairly new and hasn't been used much. thanks for you help... the memorexe
  • 4 more comments
  • fxnavarro Nov 20, 2007
    I have the exact same problem as the one indiated here. I've owned the camera since June. In September, the camera began telling me that the batteries needed to be changed. I did that but the same message keeps appearing.
  • Anonymous Nov 24, 2007
    I have the same problem. Purchased the camera in August - it is in almost new condition. Batteries have been changed. It allows me to flash a picture, but then immediately shuts down and tells me to change the batteries. Can anyone help?
  • gigione Dec 27, 2007
    i'm having the same fxxxing problem with the same camera.Somebody please tell me what the fxxx, i can't believe one brand new camera could have such this stupid problem...
  • Civsgirl Jan 02, 2008
    Exactly the same problem. Camera is new (4 months old) has not been dropped or abused, and yet I am now getting a "CHANGE BATTERY" notice when camer is turned on. Batteries have been changed several times. No Dice. Allows one photo to be taken and then shuts down.
  • el3men2dr Jan 13, 2008
    have the same problem changed batteries to new one and still get the low battery icon anyone found a solution for this>
  • paley1 Mar 07, 2008
    I purchased a CanonPower Shot A550 in October 2007.
    I experienced this problem that is, the Camera says to change the batteries without even using it. After a week of this I took the camera back to the retailer and they gave me a new one.
    Guess what...the same thing happened again. I've put in fully charged batteries each time and when I power up the camera it says to change the battery and shows me the flashing low battery icon. I haven't used the camera THAT much.
    I feel let down by what supposedly a quality camera from Canon and feel that Canon should take some action to resolve this issue. Does anyone know if there has been a resolution?
Have same problem, but still no answer, a got a cheap kodak camera and it work without any problem.
Posted on Apr 17, 2008
Return the camera
Posted on Apr 07, 2008
I've only had the camera a few months and am having the same problem.
Posted on Dec 19, 2007
SOURCE:
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery charging shows quick green light
Ill try to help you, I think the slow flashing green lite is when you first plug it in the longer its on it will flash quickly when almost finished mine blinks untill full then stays on try to wear your battery all the way down then try to charge again good luck
Mar 24, 2014 | Nikon COOLPIX L19 Digital Camera
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
FZ-100 shows number +/- 1-1/3 next to the flash icon in circle, what does that mean, flash is working ok but seams not enough flash power
This probably means the flash power is set to 1/3 of the full flash power.
Go into the camera's Menu and change the flash setting.
OR
If you cannot find how to change this setting, then remove the battery for 15 mins, replace the battery then go to the camera's Menu to set the Date & Time. the camera will be restored to the default settings.
Feb 28, 2013 | Panasonic Lumix DMC-FZ100 Digital Camera
My wildgame camera model S4 will not power back up, I've changed the batteries twice and checked them with a volt meter to make sure they are good. I've only had the camera for 1yr.
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Oct 17, 2012 | Wildgame Innovations S4 Digital Camera
My toshiba satellite a205 will not start. the battery light flashes 6 times and stops, no other lights come on. I've tried removing the battery and power cord and holding down the power button for...
If it does the same thing w/ the battery removed and just on AC, it's a power regulator problem on the motherboard. If it works with the battery out, the battery is dead and you need a new one.
Jun 30, 2011 | Toshiba Satellite A205-S4617 Notebook
My Honeywell Ademco 6160 Alpha Keypad Vista 10E low battery light keeps flashing even after I've change out????
The low battery light will stop flashing when the new battery you just installed become fully charged. It will take some time for the new battery to become fully charged.
Jun 06, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Nikon Coolpix L11 digital camera won't turn on
if u have cheap batterys in it it might be that try puting some duracellor some good batterys.
Jan 15, 2009 | Nikon Coolpix L11 Digital Camera
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A550 Digital Camera Logo
192 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
