Speakers blown or wiring unhooked to those speakers. or speaker wiring messed up somewere between radio and speakers.
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
SOURCE: one speaker works all the time the others only sometimes
Could be intermittant wiring issue or the speaker itself.
If you have another spare car speaker you can hook up temporarily, I'd start there. Disconnect one of your "bad" speakers and hook up a known good one. If the temp. speaker works OK all the time, then you know you wiring is okay.
Let me know if more ?s!
SOURCE: Durango Radio fade does not work
check the connection atr the back if their ok or maybe you just have a loose wire on it...
SOURCE: durango radio fade problems
Your front speakers are more than likely blown. They make all kinds of different models and price ranges to look at. This gives you a good opportunity to upgrade your stock speakers to handle what your throwing at it.
SOURCE: 1998 bravada has six radio speakers; two dash
i have a 98 Bravada,I had to replace both rear door speakers.
