Ok the belt broke i replaced it now its all most fine except for when is time to take out the water stars but 15 seconds after it stops and smells as burning motor it resets it self after a minute and dos it again
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
well the belt is not loose, will you have another clue
thanks for your comments to try to help me any way ....
the belt has like 1/4 to 1/2 of deflection the belt also has a tensor that is helped by a spring so the belt dos not look like the problem the key thing here is that the motor stops like is forcing it self..( question dos the pump starts to pump out water before is spinning or dos it do it at the same time ?
