Question about Toshiba 27A34 27" TV
My tv i have a tv and its toshiba when i turn it on the volume goes all the way down by itself then if i leave it on the volume goes all the way up i also have another big screen tv if i turn it off and leave it off when i got to turn it on it keeps shutting of until about 50 times that i keep turning it on it is a phillips
    Guru:
  • 416 Answers
I wouldn't advise changing the eeprom... you will need to fully adjust the TV after doing so. Not a good idea. A simple solution my be found by examining your TV control buttons. Inspect the travel and tactile feel of the volume buttons on the TV (not remote). You may have a button that is depressed and causing the problem. Another common problem occurs when the owner cleans the face of the TV with solvents (Windex) by directly spraying the surface. Solvent leaks between the frame and the CRT and ends up corroding the control button. If this is the case, you will need to replace or remove the faulty button. If you have a remote, elimination of the button is the simplest solution.
Posted on Mar 13, 2010
  • 88 Answers
Sound like the epprom ic bad, replace it with same part#. good luck!
Posted on Jul 28, 2009
I get dobble picture
Posted on Jun 01, 2008
SOURCE:
My 40 toshiba model # 42av5000 hd, lcd flat screen, my volume goes down by itself
hi select menu sound setting look for avl if it's on turn it off, if this don't work, you may need to to replace the mainboard, thanks
shaun
May 15, 2017 | Toshiba Televison & Video
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
Volume on my Toshiba TV 32AV502U goes up on its own at random times. Remote brings the volume down but within minutes volume goes up again. Solution??
First off, take the batteries out of your remote to see if it is a problem with your remote, if it is I would buy a new universal remote and try that. If none of this works then the problem is with your tv itself. Either the volume button on the tv is broken and works on its own, or the tv is having programming errors and you will need to have it fixed.
Jun 26, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
The volume on my tv goes down all by itself. I turn it up and it goes right back down to 0. With remote or manually, does the same thing. Also, can't turn tv off. have to unplug it to turn it off. Any...
Try taking the batteries out of the remote or taking it out of range from the tv. Then try turning the volume up on the Tv manually. If the volume continues to go down on its own then it is a problem with the tv set itself. If the problem stops with the remote out of the picture then it is a remote problem. As far as powering the unit off may be a similar issue. If there is an on/off button on the tv and it works to turn the power on but not off then it is a tv issue. If the remote turns the tv on but not off it may be something as simple as the wrong code being programmed into the remote(universal remote) or if it is the factory remote it may be an issue with that. You could try getting a new universal remote that works with your unit.
Jul 09, 2010 | Toshiba 32A33 32" TV
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume decreasing to zero by itself
Have you looked to see if the Button on the tv itself is stuck in. Press it and you might be able to feel for it sticking. If this is the case you may want to try a baby wipe or something similar to try and sort this out. (dont use a sopping wet cloth)
hope you get this sorted.
Little Dish Fitter.
Oct 07, 2009 | Toshiba 32A33 32" TV
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Toshiba 27A34 27" TV Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
