I bought this television second hand and the colours are off on the alignment screen. I read that you can change them in the service menu, but I can't seem to access it no matter now many different ways I try. Also, I have a universal remote. And imput would be greatly appreciated. Thanks
-   The root of the problem could be the universal remote, which would be all kinds of unfun. Pressing and holding the menu on either the tv, remote, or a combination of the two just results in the regular menu popping up for about 60 seconds, this is dissapears. Continuing to hold menu then pressing the buttons, OR releasing it and pressing the buttons results in the same thing... the TV simply trying to get to chanel 98 and 76... -   Guest
Apr 30, 2009
-   I tried that.. didn't work =-/ Thanks though!
-   Guest
To access the Zenith service menu: Hold down the menu button on the remote control until the menu disappears. Then type in 9-8-7-6-enter. This should do the trick. Be careful what setting you change. I would recommend writing them down before you change any. Hope this helps.
when I press the power button the light flashes green 3 times. I hear the switch click like its...
(More)
when I press the power button the light flashes green 3 times. I hear the switch click like its coming on. Then the light flashes red 6 times
Mitsubishi Big Screen has a pulsating brighness. It would go away if I turned the tv off and on but...
(More)
Mitsubishi Big Screen has a pulsating brighness. It would go away if I turned the tv off and on but now it just stays. TV is an older model
