Question about Blaupunkt Car Audio & Video
Wait 1 hour message will not cancel.
Hi, Having foolishly disabled the code & re-entered the incorrect code 3 times on my car radio, the "wait 1 hour" message appeared & whatever I try, I cannot cancel the message. After waiting far longer than the req'd period, (with radio switched ON) the message is still there. I have even disconnected the radio's supply for some time, but to no avail. The radio is a Blaupunkt, Dublin C30 & model/serial numbers are :-BP120Y1677175 & 7-640-120-510 IF anyone can help, I may be saved from the men in white coats. Thanks in advance. 1chab0d
  • bininha Oct 31, 2008
    Hi, I have exacly the same problem.
    -> BP0120Y1610840
    -> 7-640-120-510
    If anyone can help I would apreciate so much.
    Thanks in advance.
I also have the same problem, did you find a solution?
Posted on Nov 22, 2008
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
My problem is that,I have the code but radio is show error 3
When this happens it means that 3 incorrect code attempts have been made already and the unit will make you wait for a certain period before you can enter another code.
You must leave the radio powered on continuously and the ignition key must be turned to Accessories On position. Then wait for radio to reset to allow the code to be entered. This can take up to two hours sometimes.
You must not interrupt the power to the unit during the wait period or wait period starts all over again!
Hope this helps. Thanks for using FixYa.
Oct 14, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Hey there i have a 1997 BMW 328i and i changed my battery n when i started the car up my radio said code wait andd now i cant get rid of it please help me fix this. thank you ...
Hi chris,
Code wait is part of the built in anti-theft system BMW has for the radio. The ignition must remain in the on position for 1 continuous hour. Usually rush hour traffic does the trick. You will need the radio code to enter into the radio after it displays "CODE". just enter the code according to the buttons listed 1-6. ie if it ask for 13556, just enter the digits in that sequence. Make sure you have the correct code. If 3 unsuccessful consecutive entries are made, you will have to wait another hour.
Jun 28, 2011 | 1997 BMW 328
How can you get your radio to work in you 1994 saab? when you disconnect the battery what is the next step to resetting the code?
Anti- Theft Lock
1. Switch on the ignition
2. Press the VOL/ ON switch to turn on the system on, CODE IN will appear in the display.
3. Enter the 4 digit code using the preset buttons. The system will now appear.
- I believe the code for your car is 5253, but you might want to call the Saab dealer for the code
If yu make a mistake while entering your code, finish entering all four digits. Press and hold BAND switch until CODE IN appears in the display. The correct code can now be entered.
NOTE: If you enter an incorrect code three times in succession, you must wait one hour with the Audio Sysytem turned on before making a new attempt. After the one hour waiting period, the system will allow only one code entry attempt. If the code entry is incorrect, you must again wait one hour before another attempt.
Apr 22, 2011 | 1994 Saab 900
1994 900 s radio code
If the code is entered incorrectly 3 times then you have to wait an hour, with the radio turned on, you will then get 1 chance to enter the correct code. Get it wrong and you have to wait another hour before you can try again.
Check with the dealership that you have the correct code. They will be able to tell you if you give them the VIN.
Jan 02, 2010 | 1997 Saab 900
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
Resetting Radio with WAIT on an 01' Ml 320
hi,,you can not enter your code while wait is on,try to put your ignition on one position,wait maybe 3 to 6 hours to disappear the wait on display,then try to enter the code with guidance of manual,ty
Apr 03, 2009 | 2007 Mercedes-Benz ML320 CDI
try 4070 bpo120y1610840
try 0373 BP120Y1677175
Oct 31, 2008 | Car Audio & Video
I have a hyundai sonata classic 2000 model disconnected the battery lead to clean them, now the radio will not work I have a security code but not sure how I put it in to radio
Once you turn on the unit, "1 CDE" will appear on the LCD. Then using preset button 1~4 enter the 4 digit security number supplied on security card. After confirming the number, press preset button 5. This should unlock the player. If the incorrect code is entered "2 CDE" will appear on LCD and if incorrect code is entered again, "3 CDE" will appear on LCD. If, after the third attempt, the code is incorrect, the set will turn off. Wait 1 hour before re entering a security code.
Aug 26, 2008 | 2000 Hyundai Sonata
1998 Mercedes ML320 Radio code instructions
does your radio ask for the code when you turn on the ignition key. If you see _ _ _ _ or **** you should enter the code using the pre set numbers for your radio, ie, first code should be entered using the first pre set key on the radio ( number one ).
Followed by the second code number being entered using the second pre set button and so on until all of the code is entered.
After entering the full code the radio should accept, if not enter code again and press the next pre set key following, ie, if the code is 4 digits, press the fifth.
Hope this works.
If all this fails most garages will set the security code for you for a small charge. Make sure you take proof of car ownership otherwise they will normally refuse to reset the code. This is to foil theft.
Nov 12, 2007 | Car Audio & Video
Car Audio & Video Logo
1,166 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
