Question about Logitech Harmony 659 LCD Remote Control
Battery drain All, I am currently experiencing an issue where it asks to replace my batteries every 3 or 4 days. This problem just started about a week ago. My remote has not been near any liquid or other materials that might cause the boards inside to short. If you have seen this problem before please let me know what I might be able to do. Thanks
  • 2 more comments
  • drocpsu Dec 16, 2007
    I have the same problem. It started happening soon after updating my remote software. I moved and didnt have cable for a while, and when I was re-configuring my remote to my current entertainment center setup, I also updated the software. At first the batteries lasted a couple weeks, which I thought was really short. Then i replaced them with a new set of Energizers and they lasted 3 days. I don't know what the problem is.
  • Anonymous Mar 20, 2008
    GLOW STAYS ON
  • basauer00 Dec 16, 2008
    same problem need help!
  • Anonymous Feb 22, 2009
    Same problem
Exact same problem here
Posted on Sep 13, 2008
    Scholar:
  • 58 Answers
Maybe your using relatively cheap batteries with a low capacity.
I would try GP powerbank batteries or simular with charger with a high capacity like GP 2300. If it still drain quickly there is something wrong with your remote.
Posted on Nov 28, 2007
SOURCE:
Drained battery
Clean the battery terminals and cable terminals. Hook battery back up. Try to start again (with or without jumping). If it starts , make sure the charging system is working. If you have a voltmeter (or gauge in car dash). You can drive to autozone, Oreillys or most auto parts and they will check the battery and charging system free of charge.
Dec 06, 2013 | 2002 Chevrolet Venture Passanger
Check Charging system light illuminates, all electrical shuts down and engine still runs on 2004 Ford Expedition 5.4l until battery dies. The opposite has also happened with the engine shutting down and...
Try replacing the "convinence control module" and bad board can cause all elec issues explained and also cause engine to cut out and other things but that is where I would start, hope this helps-
Nov 29, 2013 | 2004 Ford Expedition
A few weeks ago my 2005 Pontiac Vibe started stalling really bad. I changed the spark plugs and tapped on the catalytic converter and it fixed. About 2 weeks later I changed transmission fluid, and it ran...
Sounds like a transmission issue. It should have its own Transmission Control Module or computer. Sometimes they require an update from the dealer. Either way you should contact your local GM dealer and have them run your VIN to see if there are any recalls that need done, (if so it is FREE) and ask to talk to a tech that may be able to offer advice to what the issue may be based on symptoms you're experiencing. Good Luck!
Nov 18, 2013 | Cars & Trucks
I have a 2007 X3 I bought certified pre-owned from BMW with 35K. Car now has 75K in 3 years. Heard hesitation in starting up and had battery replaced 2 weeks ago. Yesterday car would not start. ...
Yes
Wait on the mechanic to diagnose the real issue
then go there to the shop to discuss what you want
to authorize
Only do that in person
Get an education,ask questions & see proof
of test results
Aug 27, 2013 | 2003 Toyota Camry
I have a Model N-069M and i get a flashing code 16. I just had the unit flushed two days ago and i still get the same code. thanks for any help
I feel your pain. I am experiencing the same issue which started about 3 weeks ago. First it happened twice that first week and we discounted it. Now that my heater has been flushed the same issue is occuring. I called Noritz 3-4 times now and they are saying that I may have high manollowifold pressure and should have that checked.
FollowUp: Plumber determined my Natural Gas inlet line was too small. He Tee'd off before my manifold to other appliances and fed with a 3/4 line. Issue resolved and it has been trouble free since. (Updated 2/2017)
Feb 12, 2011 | Noritz 6.9 Gallon Residential Tankless...
A couple of weeks ago I went out to start my Kia Sedona 08, however, found it was dead. I connected up battery to another car and jump started first time (and ran it for 30mins). It then started fine for...
Sounds like a battery to me. The cold doesnt drain the battery it just makes it more difficult to produce enough energy to crank the car. If the battery is weak already, the cold just makes it worse. Replace it and move on!
Dec 08, 2010 | Kia Sedona Cars & Trucks
Jeep would not start at all 3 weeks ago . As if Battery was Dead. 2 hours later it started right up. Battery was fully charged . Been driving it every day for 3 weeks with no problems and then today it...
try taking off the battery terminals and see if they have dirt and grime behind them thats not letting current flow clean them with wire brush sounds like not getting current
Sep 24, 2010 | 1995 Jeep Grand Cherokee
Installed Delta 16955-SSSD Stainless Steel Victorian Single Handle Kitchen 16955-SSSD a couple months ago. About a couple weeks ago experienced low flow for about 4 hours then started working fine. Now...
Remove spay head from the end of the sprayer hose and turn the water on. If you have good pressure without the head, call Delta and ask for a new spray head. If you still have low water pressure without the spray head attached, call Delta and ask for a new ceramic disc cartridge free.
Sep 01, 2010 | Delta 16955-SSSD Stainless Steel Victorian...
Starting issues,
have your battery check first.ive never seen a battery that will last for 5 years.shelf life starts as soon as the acid is added to the battery.
Jan 20, 2010 | 1991 Ford LTD Crown Victoria
Logitech Harmony 659 LCD Remote Control Logo
505 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
