SOURCE: Humming noise in front end of truck
I'm having the same problem with my 2006 Chevy 2500 duramax...The humming starts at 25mph and then gets less prominent and then at 50mph it gets more prominent and louder, then at 60mph you can hardly hear it.....I did notice a little bit of leakage where the front axel meets the from diff on the drivers side.
Any suggestions?
SOURCE: Alero loud humming/roaring sound coming from front end.
That's indicative of a wheel bearing, which is why you were told to change that out. However, it's also possible that the carrier bearings in the differential (where the drive axles attach) have gone bad. That happened to me on my 300ZX several years ago, and I had to replace the diff bearings. I would have them checked out somewhere other than a dealer (you'll probably get a better price from an independent shop).
As a sidenote, to be sure it wasn't a wheel bearing, if you hear it quiet down in a turn one way but get louder in a turn the opposite way, it's likely the wheel bearing. If you turn left at speed and it gets louder, then it's the right bearing (since you're loading up that side of the car). If it gets quieter in a right turn, it's the right side (you're unloading that side of the car and not putting as much weight on it, so it doesn't drag as badly). See if you get that symptom just to be sure that the wrong side front wheel bearing wasn't changed.
SOURCE: Loud humming noise from front
I thought MY HUMMING WAS A cv.... BUT TURNED OUT TO BE MY WHEEL BEARING
SOURCE: 1998 Ford Mondeo GLX, loud humming sound, front driver side.
Most likely it's a wheel bearing going out.., If you turn to the right, or the left when driving the noise will change pitch. Been there done that.....
SOURCE: My front end makes a loud humming noise.
Alignment will not create a sound by it's self. The most common cause of humming (especially if you have an agressive tread design)is a wear pattern in the tires...check for that or rotate the tires around & see if the noise changes. If it does then you know it's in the tires. & Not always, but most of the time a bearing noise will increase or decrease in intensity if you load up one side at a time by doing 35-50 mph & turning slightly to each side.
