Question about Frigidaire GLWS1233A Top Load Washer
Roper Washer About a week ago, my 2 year old Roper Washer began making a screeching sound during the whole wash cycle. It sounds similar to when a fan belt on a vehicle needs to be replaced, but not quite as loud. It does not do it during any other cycle, and fills up as normal. The only difference is the sound.
  • 447 Answers
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Posted on Oct 03, 2007
SOURCE:
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
Whirlpool - MOD WTW 6600SW1 SER - CT 4270227 Type 580 For the past several weeks, the washer became progressively louder during the spin cycle and it sounded as if there was something rattling such as...
Sounds like you have change in the pump the coin may be stopping the propeller of the pump not allowing it to pump out the water. you may be able to take the pump off and clean the pump if the propeller is too bad you may need to replace the pump the pump part number is W10049390
Jul 15, 2011 | Whirlpool Washing Machines
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Screehing noise when furnace is running
usuall a schreeching noise during blower opperation is bad berrings which would need to be replaced. Most unit warrentys for newer units cover five year parts and sometimes 10 for heat exchanger. But most do not cover labor. Or the blower may just be off balance and metals are rubbing. eaither way your proubly gonna need a tech. good luck
Mar 17, 2009 | Ingram GMS90904CXA Heater
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLWS1233A Top Load Washer Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
