Magic Chef 9512 Electric Single Oven Logo
Vandy LaVelle Posted on Nov 03, 2013
Turbochef oven will not heat up to desired temp - low heat alert
3 Related Answers
MARLON KELLER
  • 111 Answers
  • Posted on May 30, 2008
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 11, 2010
SOURCE: Oven does not heat to desired tempature
Sounds like a Thermostat problem, perhaps sensor has gone faulty?
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 21, 2012
SOURCE: Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
TURBOCHEF TORNADO OVEN...Errors F3 Mag Current and F5 Mag Temp just began. They appear occasionally, now and then. Oven temp seems about right to me. What needs replacing or attention? Thanks!
the mag's only activate while in cook cycle, it will be hot as normal with toasted subs that are cold in the center.
AMP draw the Mag's and ohm the Mag thermal couples
1helpful
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
3answers
Turbochef Tornado doesn't always heat food internally
you could have a problem with the microwave circuit. That would really be the only thing preventing the food from heating internally. I would call turbochef and call for warrenty service again. Is the bread comming out nice and toasty. If the blower for the convection circuit is weak or sticking this also cause the same effect of not properly cooked food.
So check microwave circuit and also check the blower.
Hope this helps if you need more in depth advice feel free to ask
3helpful
Problems with TurboChef TORNADO Electric Oven f8 erro.
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
2helpful
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
2helpful
2answers
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
3helpful
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Top Magic Chef Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
