Question about JVC TH-C50 System
Subwoofer Shutdown JVC TH-C50. Worked fine until few weeks ago when the subwoofer decided it wanted to shut down in the middle of anything that was playing. It is doing it more frequently now and we cannot figure out the issue. We have checked all of the cables, the power strip, everything. It starts again when you disconnect and reconnect the data cable (which connects the unit to the subwoofer) but it won't take long before it shuts off again. The DVD player itself is fine. All of the speakers play great, and all the setting are set to the manual specs. Has this occurred to anyone else, and does anyone have any idea as to why this is happening? Thanks for your responses.
  • 2 more comments
  • wired Oct 02, 2007
    I did that aleady, and we checked every cable just to make sure because we have cats and we were wondering if they got back there and messed around, right? Nope, all the cables look good,as well as the jacks. I am leaning toward one of two things at this point: either the data cable is just bad, for whatever reason, or we need a better surge supressor strip. If it is not a cable/wire/ power issue, I am trying to figure out what else could make it just shut off like that. Usually components shut off as a means of protection from a surge of some sort. However, if this is the case, then you would think the entire unit would shut down, or other things, like the television, would also. Still trying things out!
    I think I have solved the issue. Thanks to anyone who was giving it some thought! (Power strip, by the by.)
  • trey808 Apr 10, 2009
    can't get bass from sub of jvc th c50
  • bses Mar 02, 2012
    I have a machine doing the same thing. So did u just replace the power strip....????
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Posted on Oct 02, 2007
I have a Th-C50 home theater and lost my subwoofer system cord, can I use a regular s-cord to make that connection? or is it useless with out the cord?? Please help!
Yes you can use any 2-core cable to carry the bass signal to the subwoofer. As the bass speaker cone is the largest cone in your speaker set I would recommend a good quality cable of decent gauge (thickness) to carry the bass signal.
You just need to make sure you have the right connectors for the amp and sub and make sure you connect positive to positive and negative to negative.
Hope this helps,
Chris
Mar 02, 2011 | JVC TH-C50 System
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
No subwoofer output
1. Try twisting the RCA plugs from CD player and see if they are not connecting right.
2. Replace the cable from the Cd player to the receiver
3. Try a different input
4. Try a different CD player
See if any of those solve your issue. Replacing the cable worked for me one time
Aug 30, 2008 | Yamaha RX-V995 Receiver
Jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Apr 06, 2008 | JVC TH-M45 System
Sub woofer shuts off
please check sub cable first with another good one and then change sub itself.because it draw too much power.
Jan 05, 2008 | JVC TH-C50 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
May 19, 2006 | JVC TH-M606 System
JVC TH-C50 System Logo
327 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
