Breaking phone pin
SOURCE: I need help unlocking my pin code for my phone. ( samsung sgh-g800)
call customer service and they will give you a code to put in and your phone will work again but do not turn off phone or your phone will not work again
SOURCE: lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
SOURCE: how to break samsung d880 sim lock password.
The best bet is to put your original sim (d880) , but don`t lock it.
Ring the supplier for this sim explain the situation and they will unlock it for you.
Your second sim will then work in your phone , no problem!
