Question about Motorola Mobility RAZR V3
Problem in camera & flap screen
Motorola v3 shows its half main screen and its camera is not working properly in sense when its camera start then brightness doesn't appear.so plz suggest that wht should i do.
    Brigadier General:
  • 7,752 Answers
Have the lcd replaced take it to a mobile service center and have them replaced it for you.
Posted on Feb 15, 2008
Screen has gone black, all other operations work fine....
i would imagine that the screen has gone bad.sense you said it started to fade..screen replacement is very easy on the V3. There are 4 screws on the cover under little rubber pucks.Then gently pop the back off.and you'll see the camera and the ribbon cables ..undo them carefully, the rest is very self explaining.
May 12, 2010 | Motorola Mobility RAZR V3
Display screen went black---otherwise, phone still works
display flap strip problem change it . it is also called as display flap PATTA
Aug 26, 2009 | Motorola Mobility RAZR V3
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
Jul 09, 2009 | Motorola Mobility RAZR V3
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
Screen wont come on
Hi,  This is a common problem but there is hope.  Open the phone and turn it over so that the camera is facing you.  On the
left side between the camera lens and the vol up/down buttons
squeeze that area.  This is where the ribbon cable is connected.
By squeezing this area you reseat the connection.  Let me
know if this helps you.
Oct 21, 2007 | Motorola Mobility RAZR V3
Black Screen
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
Sep 29, 2007 | Motorola Mobility RAZR V3
Motorola Razr V3 display problem
Solution this same thing happened to me - cause LCD screen going out = it's weak and thats the sign that it is giving up. To Temporiley to keep it on: take the battery out and back cover of battery off place phone in ICE section of Freezer ( NOT IN THE ICE )by the area where it gets cold leave it there for 10-minutes, then take it out after 10-minutes wipe everything up put the battery back on and restart phone & wah'la it's working....
Aug 14, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola v3
take apart the top half and reseat the cable going to the flip
Sep 25, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
