Copy following links:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Photos-of-WH40-timer.html#point
The pointer is stationary at 6 o'clock or straight down position.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
hi gene thank you for your help i realized afterwards not supposed to turn the pointer but i already did now the lights are turning off at the wrong times should i move the pointer to the 6 o clock position when i first checked the timer the pointer was at the 11 o clock position the problem im having is the timer is now turning off at the wrong time anymore help would be awesome thanks again
I included a link for setting the timer. Once the pointer is at 6 oclock, then tighten screw so it stays there. Then pull back yellow dial and rotate dial until current time lines up with the pointer. Then place on-off trippers on outer edge of dial at times you want to turn on-off.
