Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV is flickering and snap crackle and popping..
Whenever I turn my TV on, the picture comes on but it is flickering and making a crackling sound consistently now for about 20 minutes. It seemes once it is warmed up though, the flickering stops. But it seems to be getting worse each time i go through this procedure. Anything ideas on what I can do to make it stop before it pops altogether? I do not have extended warranty. Thanks.
    Genius:
  • 1,694 Answers
Replace IHVT aka flyback transformer. Part # 259296.
Posted on Oct 08, 2007
6ya staff
SOURCE:
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
Flash "Snap Crackle Pop"
I had same camera like yours, and same problem. I heard the same sound (firecracker) a while ago. Are these solution really work at your camera? Please let me know if its. Thanks in advance!
Sep 02, 2012 | Nikon Coolpix L110 Digital Camera
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
The power supply could be on the way to failing completely.
Aug 26, 2017 | Polaroid FLM-3201 Television
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
261 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
