Question about Organizers Tale Speeches
When i have to speak in front of even 20 peoples i shake that i can not say what i need to say and the bad part i;m a manager at work
    New Friend:
    Problem Solver:
  • 10 Answers
You should have to groom your personality to avoid such situations. Try to give a speech in front of the mirror, it helps you to increase your confidence level. Before delivering your speech to the people take a deep breathe and be confident.
Prepare your speech well, before your presentation. You can also seek help by watching videos and reading blogs of the expert on self-improvement, personality development etc.
Posted on Dec 06, 2017
  • 528 Answers
Public speaking can be difficult; there are several techniques to use to help you get over the stage fright you feel, meaning the fearfulness and nervousness. Many will say to imagine them in their underwear; although this may help in some situations, other times it can cause you even greater embarassment and stress( in example, if there is an attractive person there and....well, you know!)
I suggest you take some deep breaths and prepare what you want to say beforehand, in writing, on small cards ( like cue cards). Explaining that you feel nervous talking in front of groups will help, since most of them also have the same problem and they will all be sympathetic to you. The cards will help you to remember exactly what you need to say, as well as keep on track.
Start off by just reading the cards. As your comfort level increases, look up from the cards and look slightly over their heads, or glance briefly at each of them as you read. Relaxing as you go will help - as well as remembering most of them have the same problem, whether they admit it or not. When I first started playing music on the Worship team at church, I was nervous and made mistakes - but I kept on playing. Its been over a year now - I still make mistakes from time to time, but I am getting better. I really enjoy this Ministry, and public performance ( and speaking) is getting easier everytime.
I hope this helps - GOD bless and thanks for using Fixya!!
Posted on Nov 03, 2013
We have a 2002 Eddie Bauer Ford Expedition.about 2 days ago our check engine light came on.its been on for about 3 days and now its blinking. My car is shaking really heavily and it gets really bad when we...
Sounds like you have a sensor going or has gone, if you can limp it to autozone or oreilly's or even check with your local community college and see if they have a vocational auto repair program, if the engine management is ok, IE the brain box, you should be able get the error codes with a code scanner and go from there, ok?
Dec 06, 2014 | 2002 Ford Expedition
2001 pontiac grand am gt shaking in the front right end
check your tie rods ball joints to see if they need to be greased or replaced some come from the factory sealed and can't be greased even check the sway bar linkage rod ,but first thing i would do is make sure your new tires are
balanced and check the alignment hope these few tips help you find the cause of the problem
k
f
Nov 22, 2017 | Cars & Trucks
1995 Ply Voyager 3.0 V6. Feels like the front passenger tire wobbles while driving above 20 mph on straight stretches. In a right hand curve (not turning, just a curve) at any speed the whole front end...
SOUND LIKE BAD WHEEL BEARING.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS,MAKE SURE VECHICLE PARKED ON SOLID LEVEL GROUND.GRAB WHEEL OR TIRE AT THE WITH ONE HAND TOP AND GRAB BOTTOM WHEEL TIRE WITH OTHER HAND,TRY TO SHAKE MOVE WHEEL IF WHEEL TIRE MOVES WHEN YOU SHAKE OR MOVE IT ANY.THE WHEEL BEARING MORE LIKELY BAD.IF WHEEL BEARING OKAY YOUR FRONT BRAKE ROTOR RUN OUT WORN OR WARPED.
Jul 21, 2011 | Plymouth Voyager Cars & Trucks
What makes a 2001 hyundai accent shake at 70 mph?
theres a few things that could make it shake so it depends where it is coming from. if its just coming from a corner (like left front or right rear) it could be a bent rim or a bad tire. if its just shaking it could be you need new shocks or struts or maybe even springs but i doubt that its not even 10 years old yet
Jul 03, 2009 | 2001 Hyundai Accent
Front loader shakes bad, is level, and on a concrete floor
You will have harmonic inbalance about 800 rpm on most front load machines, causing them to shake termporarily as it ramps up on the spin cycle. Be sure to check if the shipping bolts have been removed. This is the most common mistake most people make while installing front load machines. If you don't remove the shipping bolts, it will cause most machines to shake violently and can cause damage.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Shakes real bad
You Probably need to Have the Tires ReBalanced. Maybe even the Front end Realigned. Please Rate My Response! Thanks!
Feb 03, 2009 | 1992 Ford F150 SuperCab
Front end shakes
check the tie-rod ends, control arms and antiroll bars are all secure.
May 27, 2008 | 1983 Ford Fairmont
Organizers Tale Speeches Logo
149 people viewed this question
Top Penguin Group (USA) Incorporated Vehicle Parts & Accessories Experts
Bill Boyd
TheodoreBrady
TheodoreBrady
Level 1 Expert
baire
Are you a Penguin Group (USA) Incorporated Vehicle Part and Accessory Expert? Answer questions, earn points and help others
