Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
clarkco,
thanks for the info... however, this vcr is looking for a vcr code when the set up button is pushed. it asks for a dvd code and a dvd code. i havent found the normal channel set up mode - cant find that path.
thanks, rod
THANKS AGAIN...
THE MODEL # IS: PV-D4762
FOUND ON THE BACK OF THE UNIT.
ON MY TV'S I DO AS YOU ORIGINALLY SUGGESTED AND THEN GO TO AN AUTOMATIC CHANNEL LOAD --- ALL THE CHANNELS LOAD UP. BUT HAVEN'T FOUND IF THIS UNIT WILL DO THAT.
THANKS, ROD
P.SP YES I HAVE THE REMOTE..
ROD
CLARKCO,
THANK YOU SO MUCH ... THAT MANUAL WAS A LIFE SAVER. I AM ALL THUMBS WHEN IT COMES TO THIS STUFF... BUT YOU MADE IT ALL WORK OUT BY FINDING THE OPERATION MANUAL.
THANK YOU ... THANK YOU..
ROD MYERS
