My Aqua1000T stops dead immediately prior to the final fill of the final rinse. Otherwise it works ok on all programs. I have swapped out the mainboard for another one, yet the problem persists. Any ideas ? I doubt it's the heating element as the washer only stops prior to final fill / rinse
Comments:
Oct 02, 2007
- Thanks very much for the quick reply. My washing machine is in France at my caravan. I'll buy a new solenoid here and take it with me to try in a couple of weeks. Thanks again, I appreciate it.
-   first my machine would.nt spin. i took the pump apart and found a hair elastic wrapped round the pump. the machine then spun, but now it wont fill can you help me. i put the cycle on normal wash and i can hear water but not throu pumps-   lodgey99
this sounds like the conditioner solenoid, this is the cold water valve that works as the final rinse is suppose to work, just before the final spin, check valve connections for open circuit electrically, work safe unplug from power supply first, if i have helped please rate me
candy aqua 1000,goes through wash cycle but when it gets to rinse/empty spin it just hangs there. so...
(More)
candy aqua 1000,goes through wash cycle but when it gets to rinse/empty spin it just hangs there. so water is in drum but will not empty then spin.
My Aqua1000T stops dead immediately prior to the final fill of the final rinse. Otherwise it works...
(More)
My Aqua1000T stops dead immediately prior to the final fill of the final rinse. Otherwise it works ok on all programs. I have swapped out the mainboard for another one, yet the problem persists. Any ideas ? I doubt it's the heating element as the washer only stops prior to final fill / rinse my 1000 es shuts itself off stops multiple times durring washes, sometimes it won't start again unless you restart the whole cycle and most of the time it doesn't drain itself. This has developed progressively over the coarse of 6 months.
The machine will not operate or run/start any program. Power is is ok fuse ok, door Locks and LED...
(More)
The machine will not operate or run/start any program. Power is is ok fuse ok, door Locks and LED illuminates but then nothing. Any ideas? I am an electrician and it's a friend's machine. Not got a lot of money and trying to help her. Thankyou
