This would depend on your settings. Please restart your device and check for the blue light again. Try to play a few songs and continue to observe for 10 minutes. if there is no light that means, that the blue light was not normal.
Then, you can reference the product manual about the light-based statuses and/or flashing patterns to uncover the underlying issue..
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Make sure that the Guitar Wireless receiver, microphone, and drums are connected to the USB hub provided with Special Edition. Ensure that the foot pedal is connected to the drum set. Then, perform the following:
1) Ensure you have fresh batteries in the Wireless Guitar
2) Insert receiver into USB hub
3) Turn on Guitar via switch on back.
4) If both the guitar and the USB receiver is flashing blue, then press the guitar logo button until flashing blue light on the receiver stops flashing.
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008 Definitely it is not your
computer. When it was given the signal to go OFF, it did but like
completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the
monitor still exhibits same issue after setting your Power Options as
displayed above,
check your warranty with that monitor and exercise it.
