Question about Canon imageRUNNER 8500 Copier
Error Number is showing
I had turned on and off the machine multiple times.Even unplug the machin, but it keeps popping up an error screen E000532-0001. What does this mean?
  • 62 Answers
This error occurs when the stapler assy hasn't moved back to home position upon start up. This could suggest that the stapler assy has become free of its runners and crashed into the paper delivery assy. Try and see if you can get it back on its runners through the stapler door. If not, call an engineer. Hope this helps.
Posted on Oct 02, 2007
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
Showing machine trouble, sevice call(c0500) pls help
If this is a printer/copier;
If not try reposting with model type ...
Mar 06, 2017 | Office Equipment & Supplies
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
Canon imageRUNNER 8500 Copier Logo
1,180 people viewed this question
Clive
Clive
old marine
old marine
