Question about Memorex MLT3221 32 in. LCD TV
Memorex LCD 32": after about a year a black rectangle about 24" long by 1 1/2" tall has white numbers and letters show up for several minutes goes away. Then a few days ago a large black area of about 15" wide by 8" tall shows up and you can see thru it, more dark Gray transparent, no letters or numbers, and stays on for several minutes and then goes away. I bought the tv from a friend who said there is a dead pixel, which I can sometimes see just a tiny white spot, but I'm wondering if it is causing the problems.
    Scholar:
  • 108 Answers
Check the settings and see if he has any CC1 or CC's activated or any type of Closed Caption. The only time something like this happens is usually when you have it set for CC2 or something along those lines.
Posted on Nov 03, 2013
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Posted on Apr 23, 2009
My screen goes directly to black when I turn on the television. The Memorex trademark comes up first and that's it.
I worked in electronic repair for 20 + years and recently have have this model in my shop...the problem turned out to be a ruptured electrolytic capacitor on the power supply board reference number EC17 in the backlight inverter supply....Changed this capacitor along with the capacitor next to it ref # EC18, and television worked fine...these capacitors are rated for high temp and high frequency...their value is 10uF/450Volt 105 degrees C...you can obtain them from NTE electronics at a cost of about 4-6 dollars each.
Nov 15, 2010 | Memorex MLT3221 32 in. LCD TV
Problem with the Memorex MLT3221 32 in. LCD TV. When i turn on my TV it displays "Memorex" and very quickly, then it goes black. I took the back off and the red light is on on the power board. But, I am...
I would actually not recommend opening the TV since you could get an electrical shock. I can suggest you to unplug the TV for a while (30 minutes) and then just plug it back in and turn it on. If that does not work, my recommendation for you is to take the TV to a local repair shop. It may be a fuse or internal component shorted out, but in this case is better to have a technician check the unit.
Aug 26, 2010 | Memorex MLT3221 32 in. LCD TV
Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Jul 29, 2010 | Memorex MLT3221 32 in. LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a 10 year old jvc model av27120 serial number 1251053, my 2 year old grandson touched the buttons on the front of the set and now a black rectangle keeps popping up in the middle of the picture. Can...
Sounds like 'picture in picture' was turned on. And if there is no 2nd video source, it shows up as a black rectangle. Find a button that is labelled PIP or similar and press it, maybe several times. It may move the PIP around the screen before turning it off.
Apr 02, 2010 | JVC Televison & Video
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at [email protected]
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
White Display
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Apr 18, 2009 | Princeton Digital VL1716 17" LCD Monitor
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Memorex MLT3221 32 in. LCD TV Logo
106 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
