Question about IBM 4900 4-Line Cordless Phone
4900 phone problems
About 11 months after purchasing the 4900 cordless phone the low battery light flashes and the battery doesn't seem to charge from either location on the phone. When I measure battery voltage at the battery it shows 4 volts, maybe the current is not getting to the handset? Office max would not warranty it so I boxed it up for a while but would like to get it working. Thanks
  • 45 Answers
Probably need new battery, you can get one here - IBM 4900 Cordless battery
Posted on Jul 16, 2009
SOURCE:
I have not used my Panasonic KX-TCD200CX cordless a Month. Now when I plugged it in, it does not seem to be charging. The screen is blank even after 5-6 hours of charging.Please advise what I should do...
Possible that the battery Voltage has gone BELOW the THRESHOLD level and so will take a long time to come up so that the display light ups. It is best to see if the battery is leaked, damaged or the connectors clogged. Test the voltage on the battery and replace if the voltage is low. Also keep the phone plugged on overnight so that the circuit warms up and clears all disturbances.
Jun 17, 2011 | Panasonic GigaRange KX-TG5432 Cordless...
My iDect X1 phone flashes and beeps on and off when on the charging base
The sound and flash is when the contacts on handset touch contacts on base, if the handset is positioned correctly- check the contacts, wipe them over with a clean lightly damp cloth. If the problems persist I suggest new batteries which can be purchased from Idect directly by calling 0845 345 9677- they will be posted by First Class Post and do not charge P+P.
Nov 14, 2010 | Uniden Cordless Phone
Charging light flashing all the time, is this supposed to be like this
hi, does it flash when you are charging it? if yes its normal...or does it flash when the battery is low? if yes its also normal.
cheers.
May 27, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Iam useing sony ericsson w850i for past 1 year.suddenly one day it was switched off if i seem to turn on it is flashing the red light.and now iam not useing that phone any ideas to turn on my phone back.
from my own experience and idea, I think that flashing light indicates low battery.
This is usually common with Sony ericsson phone, it flashes a red light once battery is low and you want to power is on.
Maybe should test your phone with another battery.
All the best.
Jan 05, 2010 | Sony Ericsson W850i Cellular Phone
Flashing red light
I had the same problem, blinking for no apparent reason. I shut off phone, removed battery, put battery back in, turned on. No more red light. Not sure if the charging routine gets stuck in some loop or what, where it doesn't realize it isn't charging anymore? I think it's supposed to blink while charging isn't it? Sure would be helpful if the manual said SOMETHING about it.
Aug 06, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Phone does not hold ''charge'' when removed from the charger
hi
it seems that the battery in the phone is dead. replace it with new batteries, always go for rechargeable alkaline batteries.
hope it helps
RAhUL_hunk
Mar 10, 2009 | Uniden Cordless Phone
Uniden cordless phones
Okay, this solved it for me, so maybe it'll help others.
Basically, you just need to re-register the phones by placing each one on the base unit and leaving it there for at least five seconds after the charge/in use LED light stops flashing.
According to the manual, it's necessary to re-register each phone after a power failure or if the batteries get very low or die. If you're experiencing the "connecting..." problem, this will probably fix it!
Mar 21, 2008 | Uniden Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
Model28112 series cordless phone multi phones 4 total
This does not sound good. If you have one working phone and you have swapped batteries around and still the same single phone works.... you know it's not the base unit, charger stands, power supplies or batteries. You have eliminated everything but the phone itself. Unfortunatley these low end cordless phones cannot be expected to last. 6 months is pretty bad but I'm not surprized. These sell for $30 each new and I bet a replacement battery is $20.
Jul 01, 2007 | GE 28112 Trio Cordless Phone
Open Questions:
See all IBM 4900 4-Line Cordless Phone Questions
IBM 4900 4-Line Cordless Phone Logo
136 people viewed this question
Top IBM Lands Phones Experts
Ekse
Marvin
Marvin
Are you an IBM Lands Phone Expert? Answer questions, earn points and help others
