Microwave Ovens Logo
Posted on Oct 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repairing Microwave I have a GE Microwave. The model number is JE1540WW002. The microwave timer works, but it does not heat anything, the turn table doesn't move. Should I just replace the two switches and the door latch? Any help would be greatly appreciated.
  • 5 more comments
  • CyndiAH Nov 12, 2007
    I have the same trouble with my GE - JE1540GW02 microwave. Hoss81, did you get yours working and if so, how? Thanks
  • DonaldWT Dec 16, 2007
    I have a JE1540GW and the fan does not come on.
  • jeev Jan 07, 2008
    Same problem, does not heat and turn.
  • JasonCheng Feb 04, 2008
    I have the same problem My model number is JE1540WW 003.
    The first 3 days it started to fail, the way to close the door, I kind of lift the door when closing, 50% chance it will work, ie head the food, buzzing souned, turn table turns, etc. It got worse the more I tried. Now it totally won't work
    Jason Cheng
  • sshurts Nov 08, 2008
    Same problem as describe, did anyone find the problem part to replace?
  • Anonymous Mar 27, 2014
    The top door latch has strapped off a clean break at the base of the microwave ,how can I repair it please
  • Anonymous Mar 30, 2014
    replace latch
Devabhakthuni Venkateswara Rao
Level 2:
Champion:
  • Expert 225 Answers
  • Posted on Oct 05, 2007
Expert
Level 2:
Champion:
Answers
225
Questions
0
Helped
84959
Points
295
Check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Why microwave does not heat anymore
Well, we are looking at a bad magnetron, cracked high voltage diode, or a shorted high volage capacitor. I would suggest replacing the microwave oven because the expence involved to have it serviced.
Microwave won't heat, appears to be on.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhdfs
5helpful
Unit does not heat up the lighy works the timer works the turn table works there is no heat
Most likely the magnetron is at fault if everything else appears normal. This is the main part of a microwave & is an expensive part to replace, it might be more economical to buy a new microwave.
2helpful
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
