Question about Epson LQ-590 Matrix Printer
LQ-590 skip-over-perforation (s-o-p) issue
I am printing long continuous graphs using program designed to produce same (obviously does not want s-o-p). I am using fanfold NCR tractor feed paper. Even though printer is set to not s-o-p and set for "roll paper", it skips anyway (Tried using both remote software and printer buttons to change defaults). Epson had me install LQ-570 driver and set up new paper type for 8.5" x 43". Using this driver, the printer does not s-o-p (finally), but does indent the graph about 1/4" for a few lines every 43" (bummer), then continues on with the job to the end. This workaround is ok for drafts, but not for finished work. Hint: the LQ-590 setup does not see the new paper type, so I have to use the LQ-570 driver to get anywhere. Any advice on how to REALLY overide the s-o-p in the LQ-590? Is there some other command that is interfering with the s-o-p setting?
SOURCE:
MJS_1
  • 150 Answers
SOURCE: epson LQ -590 PRINTER PROBLEM
  1. You text page is larger than the printer page,
    margins are set wrong, or there are special
    formatting marks and/or characters at the end
    of your documents.
  2. Check default printer paper-size settings:
    START --> Printers & Faxes -> Chose printer -->
    right-click --> properties --> ....
    This sets the default settings, that are in effect every time
    an application starts up.
    Also note, that if printer settings are not listed within
    your START menu, you can find them in the Windows
    control panel. You can change what shows in the
    START menu and what doesn't by right-clicking the
    task bar.
  3. Now start your application and do the same thing under
    the file menu:
    File --> Print --> Settings ...
    File --> Printer settings ...
    File --> Page setup .... and also margins. etc...
    This sets the actual settings for this application or the
    current document. These settings over-ride the global
    default setting in item (2)
  4. To clarify, the settings in item (2) should be setup to
    reflect the way you use the printer the most often.
    The settings in item (3) reflect the actual document you
    are trying to print now.
  5. Be careful that the paper size settings (3) accurately
    reflect the paper in the machine, do not confuse
    metric sizes: A1, A2, A3, A4, A5 ....
    with English sizes: Letter, Legal,..... etc
    These do not line up exactly.
  6. Also check your document, to make sure that there
    are no extra characters at the end of your document:
    Paragraph marks, Page Brakes, Form Feeds, etc.
    Also check the paragraph settings (in Word for Windows,
    for example, to make sure that is not the cause of the
    problem.
    In word for Windows, for example, you can also go
    into tools, options and change the way your document
    is displayed, such that all formatting marks become
    visible (or click on the paragraph tool)
  7. Finally, most Windows applications offer some kind
    of print PREVIEW facility, so that you can see what
    you are going to get, before you physically print it.
I hope this solves your problem, please rate my answers.
Good luck.
Martin
Posted on Jul 18, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
  • 508 Answers
SOURCE: what brand off print server can support LQ 2180
netgear!!
Posted on Jun 22, 2009
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
Basti
  • 1447 Answers
SOURCE: what are the nos of lines that are printed using
Hi
Register to epsonexpert.com so you can get the technical details for it. Hope this helps.
Posted on Jan 12, 2010
Epson Lq 590 printer job gets stuck?
Hello!
Here is the manual to EPSON LQ-590.
Hope it helps resolve the problem.
https://manualsbrain.com/en/manuals/1175640/?page=5
Nov 13, 2017 | Epson Office Equipment & Supplies
What are the nos of lines that are printed using LQ 590 with paper size - 21 x 30.4
Hi
Jan 12, 2010 | Epson LQ-590 Matrix Printer
When trying to take print in erp alwayas skip one page of 3 page print
for this you have to change some settings of your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size to you using paper size and enable the tear off option and( if first settings are not working enable skip over perforation option ........ hope it solve your problem ..................
Dec 19, 2009 | Epson LQ 1070+ Matrix Printer
When printing continuous Quicken checks with the Epson LQ-590, the first check prints perfectly but the second check prints about 2 lines lower than the first check, then the third check prints 2 lines...
It can be the margins set within the printer defaults or the margins set by Quicken. In your print preview within Quicken you should be able to see where the margins are set and adjust accordingly. Otherwise, you may need to go to your Epson's print queue and adjust the properties directly on the printer. A nice way to check it is to see if you can print some test checks to plain paper and adjust as you see fit!
Dec 07, 2009 | Epson Dot Matrix LQ-590 Printer
After Print job the printer skips and goes to next tearoff
check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Oct 05, 2009 | Matrix Okidata Microline 320 Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
LQ 590 POS
the driver for your printer is not installed correctly. please reinstall.
Sep 23, 2008 | Epson Dot Matrix LQ-590 Printer
Epson lq590
check if your LQ590 is set for manual feedor continuous feed. There is a toggle switch somewhere near the rubber rollers,there are symbols that will indicate for continuous paper printing or manual, select manual printing. Also in your print window,select printer properties, select manual printing. Yourprinter might be set up for sheet feeder or continuous paper printing. hope this helped.
Apr 23, 2008 | Epson LQ-590 Matrix Printer
First line not printing
It sounds like you are trying to get too much onto the labels or onto a sheet of labels. Try a few pages with a size smaller font and if that solves the problem, the issue is too much info for the epson to fit on.
WP will push the limits of any printer if you make it do so like this and the printer maker may have rounded the specs in the driver.
Update your driver.
Try changing from inches to cm or points etc to see what the limits are.
Then respect that the printer can do no more with that particular driver.
Good luck
Michael
Oct 16, 2007 | Epson LQ-590 Matrix Printer
Epson LQ-590 Matrix Printer Logo
401 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
