Question about Maytag Atlantis MDG7400AW Gas Dryer
Installation problems i have installed the dryer and i was wondering if there was a pilot light that needed to be lit or if i installed it wrong because everytime that i turn it on it just smells like gas
  • 447 Answers
Re: installation problems
Call someone -- thats dangerous.....theres no pilot light it may be faulty there not supposed to release gas unless it lights it. Its under warrany i presume Please rate my advice...
Posted on Oct 03, 2007
0 characters
3 Points
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 28, 2011 | Whirlpool Dryers
My gas dryer won't tumble or heat
sounds like a few things are wrong/ needs checked, will not tumble is usually the belt, no heat is usually a thermal fuse if the pilot light is lit. Here is a website that will assist you Tim:
May 15, 2011 | Kenmore Dryers
Pilot is not lit
There is no pilot light to light up for it ignites automaticly. If it is not working you will need a new replacement spark ignitor
Aug 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag dryer pilot light
You might have a hot surface ignitor that if broken can fall off and be somewhat difficult to locate by sight having never replaced one before.
Look at the new parts base as thats all you may have showing.
The ignitor regarless of type is very close to the gas manifold temination
going into the combustion compartment.
Replacing the new ignitor BE CAREFUL not to touch or bump the ignitors surface or it may fry out before you leave! they break easily!
I would use magnetic nutdrivers, its either 1/4 or 5/16 inch on most everything, very handy for furnace and AC work too
Aug 25, 2009 | Maytag Dryers
Is there a pilot lite that has to be lit on a roper gas dryer
Aug 10, 2009 | Dryers
No heat in dryer. Exhaust vent is clear
Heating element will need to be replaced
Aug 01, 2009 | Dryers
General question on pilot light
Gas dryers have electronic ignition. No pilot to worry about. Dry away. Careful, don't lose those socks now. Have a good day.
Jun 30, 2009 | GE DBXR463GB Gas Dryer
Roeper Gas Dryer not heating
 If your unit has a standing pilot, is the pilot lit?  If not, push the Basso control button and light it according to the instruction sticker.
Next, the main thing you should suspect is the capillary tube.  This thin tube runs from a hollow bolt on the gas control to the gas burner. If defective, it will not allow the unit to light off further.  Remove the tube, take it to the hardware store and get a replacement and install.  If these two items don't fix the unit, get professional help.
Dec 12, 2008 | Roper Dryers
Maytag Atlantis MDG7400AW Gas Dryer Logo
78 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
