Question about Janome Memory Craft 9000 Computerized Sewing Machine
Will not embroidery
Will only straight stich and will bring the needle all thr way up
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Presuming that you know how to correctly operate this machine, this does not sound good. Most often it is an electronic board that has failed. If so, it will be expensive to fix.
Posted on Oct 22, 2007
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Brother Sewing Machines
My zu2-b612 is good on other fabrics but its not good in cotton....
adjust the needle thread tension for different fabrics and thread sizes
Oct 01, 2016 | Sewing Machines
Straight stiches great. select any other stitch and it stitches about an inch and then stops
Test: With straight stitch and needle on left side sew.
With straight stitch and needle on right side sew.
Does one of the two sew and the other not sew?
The reason is the timing of the needle and bobbin are not set right. In other words it is in need of timing from a repairman.
Dec 12, 2015 | Singer 8763 Curvy
Why won,t my memory craft 4000 sew on straight stich setting it will sew a straight stich only on zigzag
sounds like the machine needs a adjustment, it would be a good idea to have the machine checked
Dec 07, 2014 | Janome Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
After using the embroidery hoop you can not sew in regular mode, feed dogs does not come up and moved the cloth.
My Janome has a metal slide switch for lowering the feed dogs on the base of the machine in front.
Have you raised the feed downs again? Otherwise, turn off so that the current stich selected resets, and then turn on and select straight stich. Try again.
Feb 27, 2011 | Janome Sewing Machines
How to use double needle
That stitch is called a coverhem or a coverstitch. It is made with a coverhem machine which is basically a serger with an orbiting looper. Many upper end home sergers have coverstitch capabilities (Elna 945)
To use a double needle, simply thread two threads the same way that you would thread one. ONLY USE A STRAIGHT STITCH, AS THE NEEDLE WILL STRIKE THE PLATE IF IT ZIG ZAGS TOO WIDE.
Jan 05, 2010 | Bernina Artista 180
Yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Feb 11, 2009 | Brother Sewing Machines
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Singer CE-100 Futura
Dear Nancy,
If you do not get any error message, and the proble does not depends on your procedure ( eg, you left straight stiches plate mounted, or check that is not set width to zero for the straight stitch etc. ) Then a serviceman need to reset the machine from a jumper on mainboard, or reinstalling firmware image.
If you are not in a hurry, you can also try posting the question on this website.
If is not a simple solution problem, and the machine is new , the best thing to do is calling service, as suggested by the Singer manual.
Regards
Apr 13, 2008 | Singer CE-100 Futura Computerized Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
35 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
