I have a Samsung RF265AABP model. I had the same problem on several occasions. One time the problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen. It is quite easy to remove the ice maker once you get the drawer removed from the slides. It is held in place by two plastic clips located near the back of the slides. Pop the clips out, and then lift the drawer out. Pull the front plastic cover off the ice maker, then remove the two screws holding it to the top of the freezer compartment. Slide the icemaker assembly forward about 1/2 inch and it will drop down. Unplug the wiring connector and the ice maker assembly will drop right out. The temperature sensor is located in a flexible rubber like unit that holds the sensor against the plastic water tray. This whole assembly often falls out, and may be found mixed in with the ice.
I fabricated an aluminum bracket from angle stock to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course. The tie wrap is not shown in the photos below. I drilled and countersunk two holes for the 4-40 screws holding the aluminum bracket. The temperature sensor is not shown in the photo, but the wire comes out the right side and crosses over to the left in front of the aluminum bracket.
Aluminum bracket holding sensor in place.
Ice maker assembly showing screws holding it to freezer. It is upside down in this photo.
