Question about Janome MyLock 634D Mechanical Sewing Machine
Janome Sewing machine - spring fell off
Please help!My 2 year old son took it off and I cannot get the thing back on.It is in the little door on the left side. I see where it came from. Also, does this have anything to do with the thread getting too tight in the thread tension ( the step where you wind it down into the machine front). I have never been able to get past this problem. Help!!! It is the Janome 4618 le model.
I had to take it in to get fixed because I needed it for my Christmas sewing projects. The owner tried jacking up the price on everything. I am not bringing it back there anymore.
I'll post back when the dumb machine conls out again!
Thanks!
Posted on Feb 17, 2008
  • Janome Master
  • 1,388 Answers
Can you post a photo of this so we can ident the actual spring and etc, if it is the check spring, it certainly will affect thread tension.
Post to here or via
www.bargainbox.com.au and I'll see what we can do to help if it is not too late so many months after the original plea.
SOURCE:
My Singer stylist 7258 is giving an E4 error code. It wont work at all, just give an odd sound and a high pitched sound then stops, flashing E4 on the display screen. It is only 2 months old and I live...
the brand new stylist I just bought at a thrift shop for $15.99 had a sticker on it stating, "Broken, you fix, parts in back"... I got the lady to get the parts in the back, which was the box it came in and all the accessories. Took it home plugged it in and E4 came up. I took of the nose guard with the one screw on the side, reached in and turned the coggs gently, viola, it works great.. The little servo or motor if you will got stuck when turned off in a zig/zag decorative mode. eazy fix, great machine,
hope this helps..
Michaelalan Quilting
Oct 26, 2011 | Sewing Machines
I recently acquired a Singer Zig Zag model 457. The machine was not picking up the cotton from the bobbin so I took out the bobbin and the bobbin casing. Now I cannot get the casing to fit back ptoperly so...
there are little tips on the 'backside' side of the bobbin casing you just have to wiggle the casing around keepingin mind that the back side needs to fit into place for the rest to drop on in. then you have to get just a little forceful with the the little black brace that should snug the bobbin casngback into place and keep it secure
Apr 01, 2011 | Singer Sewing Machines
My two year old son just pulled the spring off that makes the arm swing to do zig zag....I can't figure out where to hook it back on. Nothing, including the spring, looks to be damaged.
Call your local Janome dealer and ask if someone can look at the machine while you wait.
When my children were little I kept the sewing machine closed and sewed while they napped.
Mar 09, 2010 | Janome 659 Mechanical Sewing Machine
Stuck in reverse too!
There are some 3rd party vendors offering parts -
http://www.pd60.net
http://www.sewingpartsonline.com
I would recommend taking it back to your local authorized Husqvarna Viking dealer and have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for repair. They may be able to rebuild the part or get one off an old machine being used for parts. A list of AUTHORIZED Husqvarna Viking dealers is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Jul 01, 2009 | Husqvarna Viking 1
My cs6000i won't sew button holes.
You may have to do 2 things press button hole and tell it the size button whole
Jun 21, 2009 | Brother CS6000i Computerized Sewing...
Can't re-attach the stitch finger when done with rolled hemming. How do you put it back into place?
Open the front cover and working table (the door that is on the left side). On the side of the needle plate is a ****. Line your stitch finger up so that its flat side is towards the machine. On the inside of that ****, there's a little bracket to hold the stitch finger secure--it slides into that. Good luck! it took me hours to figure this out the first time! There's a yahoo group for White model sergers---they are excellent resources, too.
May 18, 2009 | White Sewing Superlock 1934D Mechanical...
Material pulling/shifting to one side
sounds like you're foot pressure is off, foot pressure and stitch length are the 2 main things that would cause "drifting" (they're also knobs that little hands could of moved) Also your little one quite possibly could of spun these knobs several times so keep that in mind while dialing your machine back to good health
Feb 13, 2009 | Sewing Machines
Thread a kenmore 158 13410????
Not sure if I am too late, but it's pretty basic. I have the same machine...
You have the thread on the spool with the thread on the left side (unrolling off the spool counterclockwise) and put it around the round thing on the front middle (looks like a snap sort of) and through the eye almost right in front of it (the loop) and hold the thread lightly then wrap the thread around the tensioner (the thing with the dial) to the left (counterclockwise) until the springs "pops" it into place. Then run the thread through the little hook thing (by entering from the left) then up to the eye (hole) that is in the little arms that raises and lowers (you might need to spin the wheel to get the arm in the right position) then you run the thread back through the hook thing (entering from the left) around the little half circle thing (by entering from the left) and finally in the hole in the needle...
hope it made sense, I tried to use laymen terms...
good luck!
Mar 21, 2008 | Kenmore 16622 Mechanical Sewing Machine
Janome MyLock 634D Mechanical Sewing Machine Logo
127 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
