Question about Cambridge Soundworks BassCube 8 Speaker
CAMBRIDGE SOUND WORKS BASS CUBE 8
I HAVE A BASS CUBE 8 FROM CAMBRIDGE SOUNDWORKS. THE TRANSFORMER HAS WENT BAD IN IT AND I HAVE NO WAY OF KNOWING THE SECONDARY VOLTAGE. DOES SOMEONE HAVE ACCESS TO A SCHEMATIC FOR THIS MODEL# BC8. IT IS APPROX. 6 YRS OLD.ANY HELP WOULD BE MUCH APPRECIATED!!! THANKS! LEXX
5 Suggested Answers
SOURCE:
  • 113 Answers
SOURCE: Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Posted on Aug 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: Lost Speaker Sound
It does sound like a connector issue, don't you think?
What happens if you DON"T touch the connector but move the volume control on the controller?
Have you tried looking outward toward the source?
Posted on Mar 30, 2010
mc1bean
  • 3053 Answers
SOURCE: How can I replace a
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Posted on Jul 07, 2011
gopakumarg43
  • 76140 Answers
SOURCE: I have a cambridge soundworks bass cube 8 that blows fuses when u plug it in how do i fix this problem and what may be the problem and where do i find someone to fix the problem for me in Nashua N.H.
Shorted component/s at its audio output stage circuit. Contact any service technician. http://electronicshelponline.blogspot.com/
Posted on Sep 16, 2016
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Why is there no bass?
Not much info to go on here, but my thought would be you have blown the woofers in the speakers, or the crossover in the cabinet, that separates the highs from the lows. . If you can touch the woofers with your hand, spread you hand wide over one, and try to move the cone. If it makes a scraping sound , the speaker is blown. If not,the crossover is probably damaged.
May 05, 2014 | Cambridge Soundworks Audio Players &...
Replacement part or schematic for Cambridge Soundworks computer speakers
I'm in the same predicament! I found this - it seems close, though the pins seem to be spaced closer together, but it looks like they might be bent to fit the wider PC board spacing. The rotating shaft also seems smaller - the original is larger than 1/4".
What do you think?
Jan 04, 2013 | Cambridge Soundworks SWBE SoundWorks PC...
Where can i buy a set of the little cubes for this style
I think this is the site for the user manual but be CAREFUL as I have not dug into the site to look for malicious code or anything. http://www.chung-sim.com/cambridge.soundworks.soundworks.digital.html
May 21, 2012 | Creative Labs CSW 100 Computer Speakers
Can one fix remote control for Cambridge sound model 88?
Take it to a Tv repair shop to see they can do something, solder connections become bad, and may need a touch up.
Mar 31, 2012 | Cambridge Soundworks Soundworks 88 CD...
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Cambridge Soundworks BassCube 8 Speaker Logo
394 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Ekse
Marvin
Marvin
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
