Question about Intel Motherboard
Motherboard needs cpu
I have a never used Gigabyte GA-81 EXW motherboard without a CPU. I have searched the web, can't find specs to tell me what CPU can be used for this particular motherboard. I did find one server unit for sale with this board that is using a P4 2.8Ghz 533FSB. It did not give socket spec, but did see that GA-EXP uses 478. Here is my question: Would I be safe using any 478 socket P4 up to 3Ghz on this motherboard? I am assuming this is a specialty serverboard, so does this make any difference using it as my home use computer?
  • sonny77 Oct 02, 2007
    syed, I appreciate the help will order the 478 in 2.4Ghz.
  • sonny77 Oct 05, 2007
    Thanks for the solution. Works fine.
    Scholar:
  • 151 Answers
No it wont make any difference. It is very safe to use 478 socket on processor with 3Ghz.
Posted on Oct 05, 2007
  • 23 Answers
Server mother boards are very fast and performance is really good. there is no problem using it as a home pc. you can use 478 socket processor
Posted on Oct 02, 2007
SOURCE:
GA-G31M-ES2L bios problem
Use CPU-Z from CPUID.com, Luke.
Will tell you what BIOS program, version, and date, you have now,
http://www.cpuid.com/softwares/cpu-z.html
Click on the Mainboard (Motherboard) tab for info on BIOS.
Need guidance in downloading, and installing CPU-Z post back in a Comment.
Regards,
joecoolvette
Jul 30, 2012 | Gigabyte GA-G31M-ES2L Motherboard
Hi, I have a used Sempron 3300+ cpu out of a eMachine with a bad M.B. I would like to know if this CPU is compatiable with a(Gigabyte), GA-M68MT-D3(rev.2.3) M.B.
Hi.
We are not going to be able to tell you if the CPU is compatible with the Gigabyte motherboard without knowing the make and model of the motherboard that the CPU originally came out of. If you could provide us with that information we will be able to tell you the socket type and whether or not the CPU is compatible with the Gigabyte motherboard.
Jun 15, 2011 | Gigabyte Motherboard GAM68MTD3 AMD AM3...
I have a Gigabyte GA-7N400-L motherboard CPU problem
dit you try a bios update?Some motherboard needs a bios update for a newer cpu.
Jan 17, 2010 | Gigabyte GA-7N400-L Motherboard
Gigabyte ga-81915me dual core support or not
Double check your model number. GA-8I915ME, its not the number 1 to the right of the 8. Its the letter, capitial i.
I did not find your excat model number at Gigabyte, open link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-8I915ME&SearchType=Spec Of the three listed I picked,
GA-8I915ME-C. Than I checked the CPU supported link;
http://www.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1954
The GA-8I915ME-C Motherboard supports both dual core & Core 2 Quad.
Hope you find this helpful.
Cheers!
Mike
Oct 16, 2009 | Intel Motherboard
No video and no posting
Your GA-7N400 PRO2 motherboard does not have a built-in video graphics card. You need to install an AGP 8x graphics card into the AGP slot on the motherboard. When you removed the heat-sink & fan assembly the CPU starts to over heat & the CPU will shut down the system. That's why you heard the, european ambulance sound.
If it wouldn’t, you would fry the CPU. Make sure you add thermal grease on to the CPU before re-assembling the heat-sink & fan. Don't forget to plug the CPU fan power connector on to the board.
Motherboard specs;
http://www0.dealtime.com/xPF-Gigabyte-GA-7N400-Pro2
Download & read your manual. Open the link provided here;
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1756
Mike
Aug 12, 2009 | Albatron PX865PE Pro Motherboard
Error beep codes on GA-6VXC7-4X
Hello kemas_franky, your Gigabyte GA-6VXC7-4X-P motherboard uses the AMI bios. Each bios has a listing for beep code errors. Click on the link provided for AMI's beep codes; http://www.bioscentral.com/beepcodes/amibeep.htm
You need to be 100% sure of how many beeps you are hearing.
5 short beeps means, the system CPU has failed. If you still have your manual, go to page 30. There you'll see the bios name is AMI.
Below is Gigabyte's web site link for your GA-6VXC7-4X-P MB.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1432
Not everyone has a spare CPU laying around so dissemble your CPU. Clean the heat-sink & CPU surfaces. To help you do this I am including a uTube video; http://www.youtube.com/watch?v=1dCa7CZ_3sI&feature=related
Try cleaning & reapplying thermal grease. (If your old grease is hardened or dried out. (Try this before replacing your CPU).
If you need a CPU & want to buy a new one you'll find a couple listed on this next link; http://www.thefind.com/computers/info-pentium-iii-socket (Prices between $10.00 & $13.00 US).
CPU Socket 370 Pentium III 100/133MHz.
If you find you heard 6 beeps & not five. Try replacing your keyboard. If that does not help than the motherboard controller is bad & you'll have to replace the board. The controller can not be repaired.
Thank you for using FixYa kemas_franky!
If you find this information helpful, please vote.
Have more questions, post here.
Mike
Jan 22, 2009 | Gigabyte GA-6VXC7-4X-P Motherboard
Iv just been given a gigabyte GA-8PE800 motherboard
Gigabyte actually has a very good website. I pasted a link below to the CPU support list.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1619
As far as what would be the best to buy I would say the closest to the top that you can afford ignoring the P4-Extreme CPUs.
Dec 09, 2008 | Gigabyte GA-8PE800 PRO Motherboard
Installing P4 2.8ghz cpu
That particular motherboard only supports AMD processors:
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1764
You will need a new motherboard to use your Intel 2.8ghz chip.
May 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Intel Motherboard Logo
115 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
