Question about Stanton S-550 Dual CD Player CD Player
Solve Problem Stanton S-550 dual Cd player
My CD player only reads cd's from the Number one player... When I insert a cd in the number 2 player,, is says no disc.. I tried to clean it but with no success,,, I have tried numerous times to insert a disc but the same problem exists.. Can you help me with this Thanks
  • rezy1 Oct 26, 2008
    I have the same problem. I jiggle the right slot as it was going in and it read ok but it doesn't allow me to do that anymore.
Same problamo........CD player mechanism needs replacement in my case!.....It could be a flexwire (a belt like flat cable inside your CD player connects motherboard and CD lense), check that out!
Posted on Nov 10, 2009
Stanton c 502 dual cd player right side skips when unit is warm
clean it with a cd cleaner an check cds 4 scratches and check the plug
Mar 13, 2011 | Stanton (C.502) 2-Disc CD Player
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
One of the CD players will not recognize disk.......will not cue up.....reading is "no disk"
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Jun 28, 2010 | Stanton C-503 Dual CD Player CD Player
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
Stanton S -650
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
May 22, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
CD Tray on one side doesn't open.
I have also had the sticking CD Tray problem with my Stanton. I disconnected the until and unplugged the separate read out control panel. I was going to strip it down, but when I plugged the power supply on it worked fine again!!!!. I wwill reconnect and see what happens!!
Dec 14, 2007 | Stanton C.501 Dual MP3 CD Player
Cd skiping
If the disc is clean, that could be some dirt on the laser head lenses.
Sep 25, 2007 | Stanton C-504 Dual Cd Player CD Player
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
Stanton S-550 Dual CD Player CD Player Logo
481 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
