Question about Epson Stylus C86 InkJet Printer
Red Paper light keeps flashing
My Epson Stylus C86 won't print. The red light keeps flashing indicating paper jam. I checked my utilities followed the instructions to the letter but it continues to say paper jam even though I checked and theres no paper jammed anywhere.
  • 2 more comments
  • khirshpa Dec 02, 2007
    My machine has blinking red lights from the ink and the paper. There is no paper jam and the ink is full. I pulled out paper that was not loading properly before this happened. Thans.
  • Anonymous Dec 05, 2007
    Paper jam
  • Anonymous Mar 12, 2014
    After paper jammed in printer I removed paper and now have E sign with all lights flashing.
  • Anonymous Mar 21, 2014
    printer will not print even though have new cartridges, machine keeps saying auto answer on load fax paper
    Genius:
  • 2,985 Answers
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Posted on Oct 02, 2007
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
Red light is blinking, What is the the meaning?
Hi, Here is the meaning of the flashing red light. Red probsolv.6.3.4.jpg paper light flashes Paper is jammed in the printer. Press the probsolv.6.3.5.jpg paper button to eject the paper. If that doesn't work, turn off the printer, open the cover, and pull the paper out from the front, including any torn pieces. Then turn on the printer, reload paper, and press the probsolv.6.3.6.jpg paper button. You can download the user's guide for this product from here. Good luck!
Mar 05, 2011 | Epson Stylus C86 InkJet Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
Stopped printing both ink and paper red light
Depending on the way the lights are flashing you could be able to fix this reasonably easily.
If the lights are flashing at high speed together (ie: at the same time) then it's a fatal error and the chances are you have some kind of problem such as:
  • paper jamming up the works
  • loose wiring
  • the cleaning station sometimes pops up out of position and stops the printhead getting back into the parked position. If this is the cause you have to push the white wiper plastic down and to the right before allowing it back up and into the mated position with the parking pad. Takes a little work but it's easy enough.
Problem #2 is the waste pads and that's indicated by the flashing lights alternating rather than together.
If it's this then rather than reinvent the wheel (I've posted about this soooo many times now) here's a helpful little guide here:
http://www.octoink.co.uk/store/pages/Epson-C86.html (the C86 is the same as the C88 in terms of the waste pump/tubing design)
Resetting the waste ink counter requires the SSC utility from ssclg.com or a suitable adjustment utility which can be found for download if you search hard...
Hope that lot helps but if you get stuck, post again and I'll do what I can.
Cheers,
Martin
Aug 03, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Feb 05, 2009 | Epson Stylus C86 InkJet Printer
My epson stylus c86 is locked flashing paper and ink red lights. The down load from epson to reset the counter for the ink foam,says the printer is no on or have a problem,
TONYCRVTTE and NOVGUNS
Have a look at:
If it's a paper jam, look for and remove paper in feed system. If no paper, is the print head properly parked under the right-hand end of the cover? If not, you may have stuck or detached parking mechanism. Come back to me if this is the case for further help.
If it's "internal error", it usually means the waste ink pads need changing. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C86 Service Manual". You will often find them
for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this advice.
Jan 13, 2009 | Epson Stylus C86 InkJet Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 printer flashing lights
then you , like the printer are stuck? well, then open it up, inspect it closely, and find the little paper that is inside and making it flash red..
Epson Stylus C86 InkJet Printer Logo
413 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
