Error message
I can't find the "50" as part of the "Unable to print" error. Usually when you get "Unable to print", it means there's a torn piece of paper, paperclip, some foreign object in the machine somewhere. Check under the scanner lid and inside the machine, look thoroughly; you may find a piece of paper blocking a sensor.
If the error message continues, follow these steps before disconnecting the MFC so
you won't lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all faxes), and then reconnect it.
Check whether the MFC has faxes in memory:
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
?OR?
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After faxes are transferred, disconnect the
MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set, 9,
0, 2 in Step 1.
Let me know if it helps!
I have the same problem-. I cleared the paper jam, and sometimes get the error code 50, and sometimes it just says it has an error. I cleared the jam, unplugged it over niight, and finally took it to a repair shop. They said the paper drive mechanism was bad and they can not get one, unless I can find an old machine and scavenge it. Since I have am ample supply of ink I will not get an HP, but another model Brother that takes the same ink. It is just over one year old.
[email protected]
I had this problem and took it to the shop to be repaired
I now cannot unistall the software or actually use the printer, i continually have error -5001 appear HELP
I cannot remove the program, i have tried numerous options
After clearing a paper jam, the printer says error 50, unable to print, how do I fix it?
