Kenmore 90 series noise after spin
I have a Kenmore 90 series washer model 20902990 which works fine except for after the spin cycle it makes a loud thumping noise. It looks like the drum keeps spinning and slows down gradually after the spin cycle. I can move the drum with no cloths inside and it still makes the thumping sound. Any suggestiions to this direct drive Kenmore?
  • edgamez Apr 04, 2009
    how do you lubricate and with what
  • Anonymous Mar 18, 2014
    It makes a banging or thumping noise while washing, and spinning.
  • 447 Answers
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Posted on Oct 03, 2007
  • joey  shearer
    joey shearer Oct 03, 2007
    please rate my help
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts.
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
I have Kenmore 90 series Model 110 20902 990. I was washing sheets and the agitator got jammed. I removed everything and now it will not spin. There also is a clicking sound. Is the transmission blown or...
The coupling below the tub and agitator has broken. the coupling hooks the motor to the transmission. Very easy repair and parts are cheap, around 20.00 for the part. While your at it get a set of agitator dogs. These are plastic tabs that go in the agitator, they are what causes it to agitate in one direction. These are also only 10.00 and it will save you a service call later. There are many posts and instructions on this repair and the best thing is you can do it yourself with little tools!
Feb 05, 2011 | Kenmore Washing Machines
Series 90 with loud buzzing/grinding noise, won't spin
It could have gone out of balance. See if the drum looks off center and center it if necessary. Turn it off and back on to reset the switch. If that doesn't work, try pressing on the lid either 2/3 of the way back on the right or all the way back on the left (depends on the model -- try both) and see if it starts. If it does, I would suspect the lid switch.
Jul 21, 2010 | Kenmore Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
You need to replace the drive block and basket drive. You can download a tutorial to get you started at The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
3,319 people viewed this question
Top Washing Machines Experts
