Question about Nintendo GameCube Console
Fan is blowing but the light does not turn on
When I turn my gamecube on the fan is blowing and everything but the light at the top does not come on and I just get a black screen. I dont know what happen. Has never been dropped and only had for about 2 years. Help me.
  • Horatio  Watkins
    Horatio Watkins Oct 15, 2007
    Thanks Grcook. I knew it was going to come to that. Already bought another one from Nintendo directly. Should be receiving it this week. Now I'm just going to take the old one apart and try to fix it. Thanks for the information. Forthakids
Sorry forthakids I had the same trouble . Had to sent the cube back to Nintendo for replacement ( had it for 6months) . So I think the best thing to do is buy a new one, then try and repair this one. GRCook
Posted on Oct 14, 2007
SOURCE:
Lasko fan wont blow air
Sounds like the fan motor is the problem
Aug 31, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
I plug it in and only the fan will turn on
Something might be wrong with your Nintendo Gamecube as a whole. I'm not totally sure. I've heard of Gamecubes working, but the fan is broken, but the other way around, that's a bit strange. If you can post some more information, can you tell me if the Gamecube actually turns on to the point where it says "No Disc", or it just doesn't even show a picture when you hit the power button.
Jul 01, 2011 | Nintendo GameCube Console
My cooling fan will not engage when I turn on the microwave. I am manually turning on the fan at High to make sure the temperature doesn't overheat the appliance. Sometimes after I'm done cooking if I...
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
Oct 21, 2017 | Magic Chef CMV1000B Microwave Oven
Gamecube cooling fan dead and resets after 3 seconds.
well, replace the fan, for a conventional computer fan.
Jul 30, 2010 | Nintendo GameCube Console
No power The light does not come on. The game does not turn. The fan does not blow.
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Dec 21, 2009 | Nintendo GameCube Console
My Gamecube won't work right.
there is to much electrcity in the game console let the gamecube rest for a couple of days
Feb 28, 2009 | Nintendo GameCube Console
Gamecube - blank screen, disc wont spin, power light and fan work.
Troubleshooting - Power
No Power
Power Light Flashes
Dec 07, 2007 | Nintendo GameCube Console
Fan not working
Some of the early Nintendo GameCube Systems released were prone to overheating, especially if played or left on on for a long period of time. If the problem is merely the cooler fan being congested with dust or pet hair, a simple cleaning will suffice. But if a clean fan and open air does not fix the problem, then there is heat damage done to the chips and you should replace the board (cheaper than replacing individual chips). You can pick up the Gamecube Motherboard CPU and Heatsink (analog type as well as the double digital & analog output) for around $15 to $20 dollars. They are pretty easy to install with just a couple screwdrivers and the bit used to open the Gamcube case. You can find them at nesrepairshop.com.
The best way to avoid overheating in your Gamecube in the first place is to make sure that your system is placed in the open where the vents on the side are not blocked from receiving free air flow. You should also check these vents periodically to make sure they are not full of dust or other blockage. If there is dust in the vents, you can use a vacuum cleaner with small corner or upholstery attachment to pull it out. But "never" us canned or compressed air as that will inevitably cause problems with circuitry, moving parts or the laser. I also use the additional little Dream Gear Digi fans that easily attach to the side to add additional cooling. These work great.
09d88c56-2167-4f57-9af3-bf36383b05c5.jpg NES Repair Shop NES Parts NES Games NES Sales Nintendo Service
Oct 27, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
