Question about Masterbuilt ESQ30B Smoker
Temp wont rise - Masterbuilt ESQ30B Smoker
Hi when driving my car the temp gauge wont move but when siting foe 5 to 10 mins idling the gugue moves up to half
Hi, I don't think you have to do much. Check that the thermostat is working properly (open and close) when temp rises.
Jun 11, 2011 | Honda Odyssey Cars & Trucks
Hi samsung fridge runs fine gets to desired temp then wont kick in again until it warms up.
the fridge will run until it reaches the temp. there should be a differential of 2 degrees so when the temp rises by 2 degrees the fridge should restart so you will need to make sure the differential is set to 2 degrees celcius on controller
May 21, 2010 | Refrigerators
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
Coolant system
think it needs more coolant added when engine is cold
Jan 18, 2010 | 2002 Pontiac Grand Prix
I have a goodman gmp125-4. The heater comes on the furnace fires up with all the burners on and it shuts off after maybe 5-6 minutes and then the module light blinks 4 times. Are there any solutions for...
You have a serious problem. That is the primary limit overload in the heat exchanger. Either your gas pressure is too high...checked with a manometer should be 3.5" w.c. for Natural gas and 10" w.c. for LP, or your air speed is too slow. If you have a restriction in the duct, even dirty filter, your fan speed will slow causing the temp rise from return to supply air to rise. The unit data plate has the temp rise range on it...for that unit it is probably 45-75 or close thereabouts. you should check the air temps a couple of feet from the unit on the return and supply duct. If the data plate shows 75, or whatever, your actual temp rise should be 10 degrees below the max on the data plate or in that case 65 higher. This unit has a three speed motor, if Black from the motor is not on the heat terminal of the control board,start there. With power off, put the black wire on the heat stake on on the board. If it is already on the cool spade, you can make a jumper and use that same speed for both heat and cooling. After this is done, recheck the temp rise on the air and see if you get about 10 below the max on that temp rise data.
If the temp rise looks good, be very careful in doing this; with power off, remove the primary limit, which is the one going into the exchanger, and either temporarily jump out those two wires or just set it aside still hooked up so the wires dont touch anything and with a temp probe or thermometer stick in the hole where the limit goes, start the unit and check the temp at that spot. That limit is 210 degrees. If it is rising higher than that and you are sure the temp rise is good, you probably have crack in the heat exchanger shooting hot air in that area close to the limit.
Hope that helps.
Jan 05, 2010 | Goodman GDS80904BNA Open Flame Heater
Temperature gauge is rising to high
when you remove your oil cap is there foamy **** on the inside of the cap, if so you may have a crack in one of your gasket
Jul 20, 2009 | Bulldog Remote Starter & T-Harness Kit for...
1997 Hyundai Elantra has heat but temp gauge does not rise.
If the coolant is below a certain level, the temperature sensor will not read anything and the temp gauge will not rise. Replace the cap, and check that you have enough coolant in the system. If this does not solve the problem, you will need to test/troubleshoot the coolant temperature sensor.
Jan 17, 2009 | 1998 Hyundai Elantra
Check engine light
sure you can have the codes checked. but lets look at your coolant temp not raising that tells me your thermostat is stuck open . the thermostat wont cause the engine light to come on and it wont say replace the thermostat it will give you the problems of running a cold engine. (try the thermostat)
Sep 09, 2008 | 2001 Chevrolet Venture
Masterbuilt ESQ30B Smoker Logo
70 people viewed this question
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
