Question about Philips Magnavox 20MS233S 20" TV
Television starts up then goes blank after a few seconds leave it awhile and it will do the same
  • 2 more comments
  • rnobson Oct 02, 2007
    Checked this out No OBVIOUS sign of damage I see blue and black ones some not standing up straight some touching other components Any other suggestions appreciated
    Thanks
  • rnobson Oct 03, 2007
    Hey I appreciate all this help Both picture & audio goes out Anyway out of town for a few I'll let you know how it goes
    R
    Thanks will check out of town for some days will post back when home
    It completely switches off and after it's cooled down with switch on again
    Problem Solver:
  • 17 Answers
Is the television staying on and going blank or is it completely turning off? I ask because a piece of electronic equipment that turns on, but then immediately shuts off normally is a clear indicator that there are some capacitors that need replacing. If this is the issue, take a look at the capacitors on the board (they look like cylinder batteries standing on end) and see if you notice any with bulging ends or leaking some fluid (it will look like battery acid). If you find this, then you've found your culprit and a $5 shopping spree at Radio Shack will be enough to fix your problem :)
Posted on Oct 02, 2007
  • Benjamin Petrofsky
    Benjamin Petrofsky Oct 02, 2007
    OK, I did do some google-cheating on this one (all in the name of assisting you though, lol). From what I'm seeing in the searches, if your television is not completely shutting off (eg. picture goes black, but audio remains blissfully unaware of any problem), you can try a "kinetic" repair. This is also commonly known as "whacking the side of the TV", hehe.
    In all seriousness, this is a real suggestion as one of the causes of this problem is a slightly loose connection somewhere which, as the TV heats up and parts expand/contract, becomes more pronounced. Hitting the TV may jar the connection back in place. While this won't fix your issue, it will, at the least, identify it for you, at which point we can move forward with trying to get the problem fixed up.
    Another thing you can try is to jiggle the video cable on the back of the TV to see if this brings the pic back as well.
    Let me know what you come up with!
Ln46a550 picture freezes when turned on
Firmware corrupted. Update the firmware. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Televison & Video
Olevia tv shuts off by itself
Likely the main board and most of these sets there are few or no boards available.
Sep 01, 2012 | Syntax Olevia 527-S11 Television
Tv comes on only for a few seconds then shuts off
Something is getting heated up inside and might need servicing. I suggest not to keep using the TV as this might damage more parts.
Aug 25, 2012 | Sansui HDLCD-1900 19 in. LCD Television
Sony bravia kdl-52w3000 picture and sound works for a while, then screen goes blank, sounds goes out
Does set do this on all inputs including one with a DVD unit connected and playing? Answer will at least narrow possible reason down a bit.
Apr 19, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv comes on then screen goes blank after a few seconds
Hello there,
If the screen goes blank after a few seconds that the phone is on. first check if the sound is still on, if it is still on, then it is the t-con board of the television that is faulty, but if the sound also goes off, then you need to check the lamp of the television if it is still okay.
Thank you for using fixya
Jun 28, 2011 | Televison & Video
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Picture goes blank after a few seconds of turning on power
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
May 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
Hitachi 65F710 tv goes blank for a second...
sounds like a possible flex module problem. repair is usually abut $500- $600.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Mar 23, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Philips Magnavox 20MS233S 20" TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
