Question about Kenmore 84072 Electric Dryer
Error Code F2
Dryer runs for a few minutes and repeatedly turns off with error code F2. Any ideas?
  • vorticity Oct 03, 2007
    Thanks for the help. Any idea what I need to replace? Hope not the computer.
  • Anonymous Mar 30, 2014
    what problem(s) are associated with code F2?
  • 447 Answers
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Posted on Oct 03, 2007
  • joey  shearer
    joey shearer Oct 03, 2007
    You will need an ohmmeter to test the sensor. I have replaced some of those exact units already for being open (no resistance). You will have to remove the front of the dryer to axcess the sensor. To have a tech repair it would run you here in Florida 1hr $75 lbr and the part around 40. If there was no other servicing needed. especially if you cn have him make sure he has a thermistor (sensor) with him...
    A solved rating is great motivation to continue giving priceless advise........
SOURCE:
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
My dryer turns off within few minutes of turning on. i get error code 55. what does that mean?
google: frigidaire dryer "put model here" error code 55. I couldn't find anything. So there's more to the error code than 55, or it is model perhaps year dependant.
Feb 25, 2015 | Frigidaire Dryers
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Kenmore 110.6807 Dryer won't run properly. In diagnostic mode, everything checks out, Dryer runs and heats. Getting F2 error in normal and diagnostic modes. I disconnected P5 and checked the switches on...
One of the first things to do when a F2 error code appears is to perform a simple reset. To do this, turn the dryer off and disconnect power to the dryer. Wait 30 seconds to one minute, restore power and turn the dryer on. Choose a new dryer cycle and push "Start" to begin. If the error code does not return to the display, the reset was successful and no further action is necessary. Hope this helps.
Read more : http://www.ehow.com/info_12001824_kenmore-elite-dryer-troubleshooting-f2-error.html
Dec 06, 2010 | Kenmore Dryers
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
[email protected] error code,
F02 - Long Drain (Drain Exceeds 8 Minutes) - Select 'cancel' twice to clear error code. Note: You may see a "SUD" error code appear first during this failure. This should change to the F02 error code after a few minutes. Proceed by checking the drain hoses for proper connection and kinks. Unplug unit and disconnect power. Check the electrical connections at the pump and make sure it is operational with no debris or blockage. Reconnect power and plug unit in. If problem has not been corrected, replace the pump.
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 84072 Electric Dryer Logo
774 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
