Question about Samsung Weather Resistant Security Camera SSC-12C
Samsung b/w ssc 12c home security camera system
The monitor fell and 2 fitting broke completely off RJ 11 cable I would like to replace the RJ11 fitting
  • Anonymous Dec 17, 2007
    need a manual for b/w ssc 12c
  • Anonymous Aug 24, 2008
    I NEED THE POWER CABLE
  • 363 Answers
New fittings (terminations) should be available from your local electronics store. They would require crimping onto the cable or soldering although I have seen a variety that screws on.
Posted on Oct 02, 2007
SOURCE:
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
Need a wiring diagram for B/W Camera SSC - 12C
Restore Deleted Data from Samsung
Here I'll introduce you Android ToolKit - Android data recovery to restore deleted data from Samsung, which has been widely accepted as the best recovery tool to recover deleted data from Samsung Android phone selectively. By using this tool, all deleted contacts, messages, call history, videos, photos, documents, WhatsApp messages, and more will be deeply scanned and recovered from your Android device. You are allowed to preview the data before recovery.
Additionally, this program enables to extract data from broken Android device, backup & restore Android on computer safely. Compatible with almost all Android models, such as, Samsung (Galaxy Note 9/8/5/4, Galaxy S10/S9/S8/S7/S6), HTC, Lenovo, Huawei, Google Pixel, LG, Sony, OPPO, OnePlus, ZTE, Xiaomi, etc,.
LEARN MORE
Jun 14, 2011 | Samsung Weather Resistant Security Camera...
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
No picture
The green connectors are for PIR (passive infrared ) motion sensors to be connected, they have nothing to do with you recieving a signal from your cameras. Double check to make sure the camera jacks are securely connected on both ends (camera & monitor) , and then hit your AUTO button which should automatically cycle through your cameras if you are indeed getting a signal. If you arent, you have other issues. As to the monitor getting darker. You will need to adjust the brightness from day to night unless you have an alternate light source or IR(infrared) Illuminator for night viewing.
Feb 20, 2008 | Samsung Weather Resistant Security Camera...
Samsung smo-120s
I broke a cable module on one of the original cables during installation. I tried to substitute a normal telephone cable with 6 pin RJ11 modules but it wouldn't work. I finally got the broken module to work but there is apparently some difference between the pins or wiring of the furnished smo-120S cable and RJ11 phone cable.
Sorry I don't have a solution but perhaps will help you find a solution.
Jan 22, 2008 | Televison & Video
Ssc-12c samsung b/w camera.
im trying to get the wiring dirgam for a ssc-12c camera
Dec 29, 2007 | Samsung Weather Resistant Security Camera...
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
635 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
