This problem should be removed because:
Problem with Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
delete RECYCLER folder
sir, I have 80GB harddisk with 4 partitions.RECYCLER folder in appear in each partition. If i delete it from those partitions it is automatically created. It also automatically copied into my pen drive. If i use my pen drive on another system it creates troubles to open files and all. please give me the solution.
Solutions (2)
Best Solution
Right click the recycle bin in 'my computer' or on the desktop and goto the properties.
You may then configure the recycle bin for each drive or turn it off altogether.
Once it is turned off for a particular drive you may remove the recycler folder (ignore the warning) it will not re-appear again when you delete files.
go to winrar if you don't have just download, then go to C: folder then look if there is a RECYCLER folder, if there is a RECYCLER folder just press shift + del button then type msconfig on the run at the startup, then go to startup.ini and disable all except for the antivirus program i have antivirus program nod32, and it appears egui.exe. den try to scan disk and defrag the system, this process is not only delete the RECYCLER folder but it increases the performance of the system.
you cannot delete traditionally, read <a href="http://www.technonsense.com/2011/02/how-to-delete-the-recycler-folder">how to delete the recycler</a> all the instructions you need, is a 2 steps operation, read the article carefully
Suggested Solution (1)
The recycler folder is a system file, it is created automatically as a place holder for files you send to the recycle bin. As far as I am aware, the only way to stop it being created is to turn of the recycle bin for each drive you have.......Doing this has the effect of permently deleting files though......
Source: recycler folder
i do not create harddisk partition
i do not create partition dm software,
recycler folder
I have 80GB harddisk with 4 partitions.RECYCLER folder in appear in each partition. If i delete it from those partitions it is automatically...
recycler folder virus
i am having 120 gb external hard disk with 2 partitions of 80 each. In both these partition, recycler folder is created and i could not...
dear sir in my 4gb
dear sir in my 4gb pen drive i am having a folder which is named recycler and its comes again and again after deleting also. so how to...
Add Your Solution
Fix-O-Meter
12,417
12,417 people viewed this problem
- 39 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Microsoft Operating System Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
