Question about Konica Minolta PagePro 1390MF All-In-One Laser Printer
MFP LOADER - RELOAD FIRMWARE
On printer's display appears this message: "MFP LOADER" and "RELOAD FIRMWARE". I know that this is about rewriting printer's memory, but how to do this? Thanks!
  • ranjeet Oct 19, 2008
Te caci in ea
Posted on Oct 04, 2007
  • eustau Oct 04, 2007
    trimiteo la ploiesti
SOURCE:
Printer display error99.07.20 upgrade
99.00.07 Upgrade not performed error reading upgrade
Description
A remote firmware upgrade (RFU) was not performed.
Unexpected read error when reading rest of header.
Recommended action
1. Download the RFU file and attempt the upgrade again.
2. If the error persists, replace the hard disk.
99.XX.YY
Description
Firmware installation error
Recommended action
Reload the firmware.
Basically you should try to reflash the firmware. If that doesnt work then you may have bricked your printer and shoudl consider warranty support or replacement. Good luck!
Dec 02, 2015 | HP LaserJet Enterprise 500 Color MFP...
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Tengo un problema con la impresora hp modelo m4345 mfp, la cual ya estaba funcionando pero de repente envio un error el cual es el siguiente 49.4c02 - error para continuar apague y encienda , ya lo...
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Jul 14, 2011 | HP LaserJet M4345 MultiFunction Printer
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
Recently had to reload everything on a new hard drive and reinstalled the Z82 drivers and updated firmware. Printer acts like it is printing but does not print anything. Any suggestions?
do you get anything from the self test? Press Setup until MAINTENANCE appears in the display. Press ?ž?or ?¿until PRINT SELF TEST appears in the second row of the display. Press Enter/Select. The message PRINTING appears in
if that works then it is definitely on the computer if not then you know it is a printer issue. When you plug in the USB cable did the computer react as if something plugged in? Try re-installing the drivers. Make sure the port selected is USB
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 30, 2010 | Lexmark Color Z82 InkJet
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
Tengo 1 page pro 1390 MF con 1 error en la pantalla que dice MFP LOADER RELOAD FIRMWARE. Creo que debo aserle 1 actualizacion del firmware solo quiero saber de que forma realizar la actualizacion y de...
Need a qualified tech as the firmware is on a secured server that only qualified techs have access to the Firmware is the printer OP system. Companies don't like having their copier op system given out freely.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 02, 2018 | Konica Minolta PagePro 1390MF All-In-One...
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
[email protected]
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
MFP on.
computer.
5 Turn the MFP off.
8 Turn the MFP on.
device.
the error message.
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
Error message come up on printer
Normaly a Check Sum fault will be displayed if the printer firmware has become corrupt or the flash memory may be damaged.
The first thing to try would be to reload the firmware into the pritner, if the firmware is corrupt this will rectify the problem.
If it is not possable to reload the firmware the main board may need to be repalced.
Nov 11, 2008 | TallyGenicom 6312 Matrix Printer
Konica Minolta PagePro 1390MF All-In-One Laser Printer Logo
1,772 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
