Question about IBM ThinkPad A21m 2628 Notebook
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
When I turn on my IBM thinkpad A21m 2628 laptop after several minutes, it always shutdown.After shutdown, it never start up when i try to turn it on.I wait several minutes and when i turn on again it was starting up and shutdown again after several minutes.I already replaced hard disk and installed new OS but still it always shutdown.what is the problem?pls help me.thank you
  • liljoey1 Dec 12, 2007
    i have somewhat similar problem. but instead it shuts down loading windows and after repeated attempts windows finally loads. i can let it sit indesktop for hours or use help or check and change window settings and it works fine but if i use certain applications it shuts down. i also let it sit in bios setup or boot to floppy and let it sit and doesnt shut down. i did a diagnostics with pc doctor in dos and it ran all tests without shutting down.
    everything passed except the hd linear test. i did a scandisk and read test showed errors when i tried the write test it shutdown. was going to replace hd but seeing other people having shutdown problems now i dont know
    President:
  • 2,961 Answers
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Posted on Oct 02, 2007
SOURCE:
How do i connect my ibm thinkpad a21m to the internet
You need the next three letters or numbers after 2628 - ___ Go here http://support.lenovo.com/en_US/downloads/default.page?selector=expand click on laptop and tablets click on thinkpad A series then A21m Then 2628 then the next three then your operating system then voila there you have all your drives and any update for your thinkpad Bookmark so you will always be able to fix what ever may be wrong.. Please rate!!!
Nov 23, 2012 | IBM ThinkPad A21m 2628 Notebook
Deiver ibm thinkpad a21m 2628
Good day!Go to IBM site and write that model of your PC Notebook..You can find the drivers there..
mastergani
Mar 26, 2010 | IBM ThinkPad A21m 2628 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Ibm thinkpad A21m 2628 floppy dr not working
Take a can or air and blow a little bit into the drive to make sure dust is not in there. Then use good known floppy disks to see if it reads at that point. If it still doesn't read then the floppy drive is bad and will need to be replaced.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
Bios password
ibm think pad r40 bios password cracker
Oct 11, 2007 | IBM ThinkPad A21m 2628 Notebook
Installing new OS
Every laptop is accompanied by a preinstalled vesion of Windows, on the same hard disk in a hidden space. So if you get a prompt to restore your laptop to a previous state at the beginning of system startup, press the relevant key. If windows xp is your choice. and want to install it you may need follow the installation instruction from your system manufacturer. When the system starts up some information is displayed on the screen, like this: " Press F1 to enter setup" If you press the relevant key and enter the BIOS setup you can find the CPU temperature settings, shutdown temperature etc... This may not be you case. So I suggest you to get support from a qulified technician. Your system hardware should have some problem. (motherboard or hard disk is more prone to error) you can also try to find information from your system vendor's manuals and support website. All the best
Oct 03, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
298 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
