Question about Sharp AR-161 Laser Printer
A3 Printing How do you copy a A4 and increase to size A3? I copy an A3 sheet and only seems to copy A4 size of image. Copier has only 1 tray installed that states A4 on it but can fit A3 Paper
  • 417 Answers
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Posted on Feb 17, 2008
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
Why better canon ir8500 than canon ir7200
Features - The Canon imageRUNNER 8500 benefits from a number of unique features including 85 ppm output, 4 trays online, 100 sheet document feeder, digital copying, built in duplex , network printing/scanning option, professional image quality and compact and reliable design. The Canon iR8500 can copy or print up to A3 paper size. This high volume copier provides an easy and efficient solution for work groups.
Sep 06, 2009 | Canon Office Equipment & Supplies
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Print or copy at A3
you will ahve to set this in the print properties when you select print on the file option go to paper and select bypass if you are using this tray and original size will be A4 print size will have to be set to A3
May 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Jan 31, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
How to set the paper size in the trays?
most are set by the trays itself, when you adjust the "guides" that go against the paper it adjust some levers on the side or back of the tray which push on some sensors behind the tray.
Some however you need to turn a dial in the tray to the paper size you need.
make sure the guides are snug against the paper, the dial or settings are correct and that there is no paper behind the tray.
Also I'm not sure what country you are from but in the US we do not use A4
Nov 23, 2008 | Panasonic Workio DP-2500E Copier
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
A4 to A3 not working
hey guys with 1520p printing preferences you may use the zoom feature to print it out on an a3 size from a4 size of your document page setup
Feb 14, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
439 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
polytek
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
