Question about Toshiba Portege S100-S1133 Notebook
Unable to install Win XP on Toshiba portege R500
Hi, I have a Toshiba Portege R500 notebook. It had win Vista installed on it earlier. Now i want to install XP on it. But ,installation halts after showing blue screen after some time. What is the cause of the problem? Can some one guide me. Any suggestion would be highly appreciated. Thanks in advance Saket
Make the SATA disk mode from ACHI to Compatibility in the BIOS. once its done without any problem you can make partitions, installa Windows XP. hope this helped you. thanks.
Ammar.
Posted on Apr 02, 2009
    Scholar:
  • 88 Answers
  1. Download all XP drivers from Toshiba and store them on external harddrive or USB flashdrives
  2. Prepare a XP Bootable CD with Intel Storage Drivers (ICH10 now) slipstreamed
  3. Boot the R500 with this CD and delete all the existing partitions (NTFS version from Vista is newer than XP, so installing XP on Vista version NTFS partition will crash)
  4. Create just 1 primary partition for Windows XP (at least 20GB prefered but please don't use up all the space, use multiples of 1024MB, eg 30G = 40*1024=40960MB)
  5. Once XP has installed and booted in, go to Computer Management, Storage -> Disk Management and change the CDROM's Driver letter to E (assuming you did what I said, originally the XP is on C, CD-ROM on D), then create a primary partition using up the rest of the hard disk space and label it with D.
  6. Copy the "i386" folder from XP CD to D drive, this will get rid of "Please insert XP CD..." at later stage when you change do some system change.
  7. install all neccessary drivers from the external HD/Flashdrive.
  8. Please also disable "AutoPlay" feature on XP as there are so many Virus/Trojans that uses this AutoPlay feature to infect and spread. (XP Pro only: Start->Run, gpedit.msc, Enter. expand Administrative Templates and click System on both Group Policy roots, double click "Turn off Autoplay". Enable it on All drives..., OK)
  9. Install your applications and do a windows update at the end.
Posted on Oct 18, 2008
    New Friend:
I have toshiba portege R500 i want install winxp fist boot device not detect in externet dvd writter what can i do
Posted on Aug 14, 2010
    New Friend:
  • 3 Answers
I install XP to Portege M200 computers by the following method
Upgrade bios from a USB floppy (get upgrade file from Toshiba online)
after upgrade the computer can boot from the CD drive and install XP. The upgrade goes very slowly for the first half of the install but is installs properly.
Posted on Apr 20, 2010
    Problem Solver:
  • 11 Answers
At wht stage of the installation do you get the blue screen. Did you try installing from a different cd. Later during the installation you might have to log on to BIOS and there will be an option called disable SATA , you will have to disable it in case your laptop was shipped with Vista or else your hard disks will not get detected.
Posted on Oct 04, 2007
    President:
  • 2,961 Answers
You will need a Vista disc to format the drive or try using the XP disc to format before you install. You may have bios and processor recognition problems running XP where a notebook is set up to run Vista
Posted on Oct 02, 2007
2 Suggested Answers
SOURCE:
SOURCE: Installing XP on Toshiba Portege R500 Notebook
Change the HDD to compatibility mode... or get the intel matrix driver and use the f6floppy directory and readme to install the driver by pressing f6 at xp startup. You will need an external floppy disk tho.
Posted on Nov 08, 2007
Hello! I have the Toshiba Portege R500/Win XP.Now it does not see the hdd. I removed the hdd and checked it with another PC-it works. BIOS does not see the hdd too. What to do? Halp me please. Vlad
Only option is to get BIOS to recognize the hard drive. No going forward without it. You could try loading the BIOS defaults. Saving, and rechecking.
Jan 15, 2013 | Toshiba PORTEGE R500-S5006X Notebook
Toshiba Portege R500 hangs when starting up.I have to shut it down again and then start it up for it to work properly.It has windows 7 installed in it
Perhaps you need to disable some of your startup programs. You have ugraded to Win 7? Has this been happening due to the Win 7 upgrade? In Device Manager are ALL the devices working? No unknown devices? Any graphic driver issues?
Jan 11, 2013 | Toshiba Portege R500 Notebook
How to install window in toshiba portege r500 laptop
You could buy an external CD/DVD drive and connect it to your laptop with a usb cable and install windows 7.
Jun 27, 2012 | Toshiba Portege R500 Notebook
Need a toshiba portege R500 vista recovery disk
Toshiba Factory Reset
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
Oct 18, 2009 | Toshiba PORTEGE R500-S5006X Notebook
I have Toshiba Portege 3110ct w/WIN 2000 installed. Have forgotten admin password- I added a wireless card and tried to set up a home network when I locked myself out inadvertently
Are you able to get in in Safe mode (F8 on boot) , maybe try Administrator with no password. Then you could reset your admin password.
Jun 12, 2009 | Toshiba Portege 3110CT Notebook
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Mar 18, 2009 | Toshiba Portege R200 Notebook
To change os from vista to XP
I hate Vista from my guts! I installed XP SP3 (Slipstreamed) and my Toshiba Portege R500 Flies!
I have posted some notes on similar issue from this forum. Use this website's search engine on "Toshiba R500" and you should be able to fine my posts.
My current job involes rebuilding laptops and desktops so many times that I created this automated slipstreamed XP SP3 CD and I had no issues of Harddrive not being found after all the waiting.
PatKam_AU
Oct 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Portege 7100 SlimLine Notebook
they should be the same the close number just means that they revised something... most laptops have builtin wi fi but if it doesnt just buy a cheapie usb or pc slot card! I would NOT reccomend that you install windows vista on your pc.....there are still yet too many problems with them and you will have A VERY hard time getting drivers that are compatible
as far as the rest of the specs... ask the seller! they should know or see if it says on the ebay auction page
~Lee Founder Of Free Tech Associates
[email protected]
May 27, 2008 | Toshiba Portege 7100 Notebook
Guys, if you have the genuine XP CD, please download the Storage Driver from Intel and slipstream it into your version of XP CD. You can also slipstream Service Packs into it as well.
Personally I hate Vista so much. It really brings out the angry devil in me.
By the way, the best and easiest way to slipstream is to install and use nLite http://www.nliteos.com/
Let me know if you want help on installing XP on R500 (I build it a few days ago, but regret to update the BIOS to version 1.06 as I lost the Ctrl key on it).
To get to the BIOS, press and hold the Esc key then Power button.
Oct 03, 2007 | Toshiba Portege S100-S1133 Notebook
Toshiba Portege S100-S1133 Notebook Logo
3,333 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
